July 26, 2021, 23:29 |
Example case (Load Condition)
Fauzan Isa
Rep Power: 4 |
Hi, I want to simulation different loading condition for this engine setup that I get from example case>internal combustion engine>heavy duty engine>full cylinder diesel engine. Under the spray modeling, the total mass of diesel used was set to be 0.0001621kg which equal to 7281.3 J per cycle (I did not change anything from the example case setup). My question is does anyone know what is the loading condition for this case setup? Is it intermediate load? and how can I simulate a higher loading condition? I aware that higher load required more fuel to be supplied for the combustion process... but is there another parameters that I have to consider as well?
July 27, 2021, 10:06 |
Chinmaya Rajath
Rep Power: 5 |
Hi Fauzan,
I believe the current load conditions are set up for high load. Since this is a made up engine it is hard to know if this is peak load condition. To simulate different loading conditions, in addition to changing the amount of fuel you will also have to change the amount of air supplied to the cylinder to achieve the desired AFR. You can do this by changing the INFLOW boundary pressure. You also might have to change the temperature boundary conditions for boundaries within the combustion chamber. Make sure you increase the number of parcels injected per nozzle if you increase the mass of fuel injected.
Chinmaya Rajath Research Engineer, Applications Convergent Science |
[OpenFOAM] ParaFOAM for multiregion case only load one region? | fxzf | ParaView | 1 | October 22, 2018 06:50 |
Simulation of Si engine(Premixed Combustion) at Part load condition | Pramod B | CONVERGE | 3 | March 6, 2018 10:32 |
Reason for divergence of continuity eqn in Periodic boundary condition case | Luttappy | FLUENT | 0 | November 7, 2015 00:13 |
Axysimmetric cases compare to planar case with symmetry boundary condition | hafiidz | FLUENT | 5 | June 14, 2011 06:29 |
reference area in case of symmetry condition | Micheal | Main CFD Forum | 1 | December 24, 2008 03:14 |
