August 9, 2023, 18:45 |
CONVERGE with GPU in Windows
Amin Sheikhi
Rep Power: 3 |
Can we run CONVERGE with GPU on Windows? I checked the GPU option in the run parameters and used a .json file. Then, I changed its pressure linear solver type to AMGX or CONVERGE BISCGSTAB GPU, and as a result, I received this warning: "You must check 'GPU configuration' and provide an AmgX file in Case Setup > Simulation Parameters > Run parameters > GPU/Acceleration when using AMGX." Additionally, when I run the simulation, I repeatedly encounter this error message: "Temperature extrapolation error found at cell." Is there an AMGX file available to set up my simulation on an Nvidia GPU? I would be very grateful if you could help me. Sincerely, Amin" |
September 1, 2023, 16:22 |
#2 | |
Shengbai Xie
Rep Power: 9 |
I do not think there is anything to exclude Windows OS from GPU usage. If you are trying to use the AMGX library and mixing it with the BiCGStab solver, I think it is better not to use GPU (since you would probably not see much speed-up) or use CONVERGE_BICGSTAB_GPU as the linear solver without specifying the AMGX configuration file (.json) file. I hope it helps. Quote:
Shengbai Xie, Ph.D. Senior research engineer, Application (608) 230-1563 convergecfd.com |
GPU Parallelization in OpenFoam | kk415 | OpenFOAM Programming & Development | 16 | January 16, 2023 14:08 |
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines | ghost82 | FLUENT | 54 | February 9, 2022 03:32 |
Call Ubuntu-based OpenFOAM solver through Windows CMD | ishan_ae | OpenFOAM Running, Solving & CFD | 0 | August 17, 2020 10:12 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
