June 26, 2014, 07:46 |
Input mesh formats
Alexandre Sapet
Rep Power: 11 |
I am considering using enGrid to generate a volume mesh from a surface mesh (like TetGen does). Then, I would like to know what kind of formats enGrid can open (I am thinking about the .poly and .msh formats). Thank you in advance, Alexandre |
July 1, 2014, 15:09 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Alexandre and welcome to the forum!
If you install enGrid, you'll be able to see what formats it's able to import! Quoting from the wiki, at least the following are supported: Quote:
Bruno
August 7, 2014, 02:51 |
Hi Alexandre,
you can PAY Oliver to add new formats if that is really nescessary. But with some python scripting you can convert many formats with paraview or VTK yourself. http://www.paraview.org/Wiki/images/...Tutorial41.pdf http://www.paraview.org/Wiki/Convert...rom_PLY_to_VTP see those readers vtk supports http://www.vtk.org/doc/release/6.0/html/classes.html |
engrid, format, openvsp, volume |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
