Home > Forums > Mesh Generation & Pre-Processing Software > enGrid
Trouble exporting from Blender to EnGrid
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 23, 2015, 20:08
Default Trouble exporting from Blender to EnGrid
N Roberts
iceBird10 is on a distinguished road
I am trying to export a blender file as a .begc (Blender-Engrid file), but I cannot find the the option on the export menu in Blender (currently using v2.70, but have tried in older versions). I've heard elsewhere that special scripts need to be installed, but I cannot find these. Can someone help? Thanks.
iceBird10 is offline   Reply With Quote
Old   June 26, 2015, 05:11
KateEisenhower is on a distinguished road
I used the scripts you find here: https://github.com/enGits/engrid/tre..._scripts/2.63a
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   June 27, 2015, 15:27
Default Thanks!
N Roberts
Originally Posted by KateEisenhower View Post
Best regards,
Kate
Thanks so much! Got everything to work.
Old   June 27, 2015, 17:28
You're welcome.
Does anyone know what the io_export_snappy.py Script is for? Description from the code:
"description": "Export objects suitable for snappyHexMesh (snappyHexMeshDict)"
I mean how does it differ from io_export_engrid.py?
Best regards,
Kate
Old   June 28, 2015, 16:40
Retired Super Moderator
Bruno Santos
Quick answer: Sadly this script was only started to be developed and it seems that it was never finished. The differences are only aesthetic and there is no difference in the core code.
If you're looking for something with the desired functionality, check this wiki page: http://openfoamwiki.net/index.php/SwiftSnap
KateEisenhower likes this.
Old   February 2, 2016, 19:40
Default Importing in blender
Riccardo
RANSES is on a distinguished road
In this regard, I seize the opportunity for submitting a different, but still comparable question. If, rather than exporting, I wanted to import in blender a fluent mesh (namely a .msh file) in order to subsequently rendering it...do you think it would be possible?
RANSES is offline   Reply With Quote
Old   February 6, 2016, 06:17
Bruno Santos
Greetings to all!
I'm going to assume you want to do this, because you want to later import it to enGrid. Otherwise, you should have asked about this... er... not sure where... maybe here: http://www.cfd-online.com/Forums/mesh-generation/
To answer your question: Blender is meant to handle the surface mesh. This means that you will need to extract the surface mesh from the Fluent mesh into a importable format and only then you can import to Blender.
If I had to do this myself, I would use OpenFOAM to import the Fluent mesh and then export the surface mesh to STL. The STL file could then be imported in Blender, although the downside of this is that the surface mesh would be composed of triangles... which if your original surface mesh was composed of 4 sided polygons, isn't a totally bad solution.
Best regards,
Bruno
Blender Export to Engrid script for Blender 2.69? eaglemckenna enGrid 12 April 23, 2020 04:37
FYI: SwiftSnap now can also export on Blender to enGrid wyldckat enGrid 0 October 6, 2013 10:35
blender to engrid Astarta enGrid 1 May 23, 2011 15:37
How to use blender for engrid? monti enGrid 1 December 20, 2010 12:43
Trouble with exporting tecplot files from FLUENT Argen FLUENT 2 January 5, 2010 02:42
