Home > Forums > Visualization & Post-Processing Software > EnSight
particle tracking from Fluent DPM in Ensight
Old   December 8, 2014, 08:19
Post particle tracking from Fluent DPM in Ensight
hosseinjanbazi is on a distinguished road
Hello
In my project, I have surface injection in Fluent with DPM model:
I exported data for two injection with two different diameters at the same surface. But in Ensight I can see two diameters as one diameter. It seems Ensight can't load two different particle diameters at the same time.
Is this happened to you? or do you have any idea to talk about it?
Thanks,
Hossein
hosseinjanbazi is offline   Reply With Quote
Old   December 9, 2014, 12:26
Default Multiple Injections in Fluent
kevincolburn's Avatar
Kevin Colburn
kevincolburn is on a distinguished road
Hossein,
Do you have multiple injections?
There is a lack of capability in the Fluent Exporter which is unable to process multiple injections out correctly into the EnSight Measured Particle File Format. In its current form, only one injection will be visible in EnSight (as only 1 injection is actually referenced in the measured file set).
If this is the case, I have a work around for this. You can contact us directly here at CEI for this utility. Hopefully future versions of Fluent will correctly handle the export of multiple particle injections to measured data format (they are aware, but is very low on their long list of things to do).
Regards,
Kevin Colburn
Kevin Colburn
Computational Engineering International, Inc.
www.ceisoftware.com
kevin@ensight.com
kevincolburn is offline   Reply With Quote
Old   November 24, 2016, 08:33
SJSW is on a distinguished road
Hi~ I am using ANSYS Fluent 17 to simulate a transient case with multi-phase flow model and DPM model.
I found that CFD-post can't display the results of these two models at the same time.
Could Ensight 10(or a newer version) handle this and produce a animation?
If it's OK, how to do it?
Thank you!
SJSW is offline   Reply With Quote
dpm fluent model, ensight vizualisation, fluent 14
DPM and particle tracking yahya FLUENT 3 March 24, 2013 11:31
CFX vs FLUENT for particle tracking simulation iman ANSYS 2 August 31, 2012 20:34
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM particle size distribution in Fluent Pete FLUENT 5 July 7, 2008 12:22
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 03:51
