Home > Forums > Software User Forums > Fidelity CFD
wrong efficiency-axial compressor rotor 37
Like Tree1Likes
  • 1 Post By Hamidzoka
Old   December 1, 2012, 09:39
Default wrong efficiency-axial compressor rotor 37
sajad
sajad is on a distinguished road
Hello
I'm doing Fine turbo v8c tutorial number1. it's about axial compressor rotor 37.
I'm doing exactly like it says
in the tutorial the polytropic efficiency for this case is 88.9% but when i solve it i get value 85.225%!
what is the problem?
please help me
sajad is offline   Reply With Quote
Old   July 19, 2014, 07:13
yujiabeizi
yujiabeizi is on a distinguished road
Originally Posted by sajad View Post
Hello
please help me
Many factors can affect your final solution. For example, your mesh ,your computer, even your weather.
yujiabeizi is offline   Reply With Quote
Old   November 6, 2016, 22:54
swm
swm's Avatar
swm is on a distinguished road
Hello
please help me
I also encounter the same problem!
How to solve it, could you please give me your suggestion?
swm is offline   Reply With Quote
Old   November 19, 2016, 04:32
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
Regarding this problem some points should be considered:
- Air properties should be carefully checked.
- Position of inlet and outlet boundaries as well as hub and shroud geometries should be checked.
- Mesh distributions, turbulence model used, blade RPM and direction of rotation should be checked.
- Spanwise distributions of boundary conditions can also have an impact on the efficiency. So, this needs to be checked.
- Blade tip clearance should be checked.
regards
colinda1 likes this.
Hamidzoka is offline   Reply With Quote
axial compressor rotor 37, efficiency
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
udf error srihari FLUENT 1 October 31, 2016 14:18
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 07:39
Efficiency, thrust/drag with regard to hovering quarkz Main CFD Forum 0 April 21, 2010 00:51
About the design of axial fans HanCheolHeui Main CFD Forum 0 September 8, 1998 10:13
