Home > Forums > Software User Forums > Fidelity CFD
Repeating failures to generate a butterfly grid near the hub fillet
Old   April 28, 2017, 23:39
Default Repeating failures to generate a butterfly grid near the hub fillet
swm
swm's Avatar
swm is on a distinguished road
Dear all,
I'm trying to utilize the 'butterfly' topology in Autogrid5 v10.1 to resolve the hub fillet region.
However, error message keeps arising, saying 'Could not create fillet geometry for blade 1. No blend surfaces created'. And, if I close the butterfly option, everything is fine.
Does anyone have any ideas on it? Appreciate any suggestion.
Thanks,
swm
swm is offline   Reply With Quote
Old   April 30, 2017, 23:37
swm
swm's Avatar
I've overcome it! Key points:
1. the unit chosen in the left panel should be consistent with the data in the .geomturb file, or the intersection tolerance set by the software through background operation according to the units can NOT generate a right fillet
2. there's a sew tolerance in the 'Blade Expansion' panel, sometimes you can reduce it a little bit.
Thanks Holger who helps me to figure it out.
Old   May 4, 2017, 04:40
Hamid Zoka
Hamidzoka is on a distinguished road
Hi
I would like to add some points to what is mentioned here:
Sometimes the position of inlet and/or outlet patches does not let the fillet fully generated. In these cases manual adjustment in positions of patches can help. This is an issue for multi row simulations.
Regards
Hamidzoka is offline   Reply With Quote
How can generate Uniform Cartesian grid? Harry Main CFD Forum 22 January 17, 2008 17:40
To generate grid for Fastest-3D by ICEM/CFD goni Main CFD Forum 0 September 24, 2007 06:40
How to generate the Grid for a Blower Problem Jaya- Athu FLUENT 1 November 24, 2002 00:54
CFX-Build 4: Butterfly Grid Anthony Williams CFX 0 October 31, 2000 12:45
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
