Home > Forums > Software User Forums > Fidelity CFD
Imopsing profile at inlet in initial solution for turbomachinery
Old   April 21, 2018, 09:15
Default Imopsing profile at inlet in initial solution for turbomachinery
Vishwas Verma
vishwasvemra is on a distinguished road
Hello all,
I am trying to do a computation of an axial compressor in fine turbo, with imposed inlet circumferential pressure profile. I have imposed the profile at inlet successfully, but each time the solver exits with error message of "this type of profile x,y is not yet implemented in the initial solution for turbomachinery ".
I am not able to find an option to put a profile at intial solution. I tried with both a constant value and with radial equilibrium, but both of them exits with above error.
I have checked in manual, and it says that '2D profiles at the main channel entrance and exit are not supported', but i am not sure then, why does the solver exits with this message.
Could anyone please help on this.
Thankyou very much!!
Kind Regards
Vishwas
vishwasvemra is offline   Reply With Quote
Old   April 21, 2018, 13:30
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Dear Vishwas,
are you really sure you correctly defined the profile? The error message ""this type of profile x,y is not yet implemented..." might mean that you used x and y coordinates instead of r and theta. Might this be the case? Please have a look at my attached figure.
May I ask if you have already worked through the manual (FINE™/Turbo > User Guide > File Formats > Files Used as Data Profile)?
Kind regards,
Holger
DarylMusashi is offline   Reply With Quote
Old   April 21, 2018, 14:05
Vishwas Verma
Dear Holger,
Yes, I think I have imposed the profile correctly. I have checked with the manual, and the data i have is for x,y and p value. So I used first line as 'FINE profile file', then 51 1000(as manual says 51 for x and y and I have 1000 data points) as the second line, after this x y and p values. I could see the imposed profile in viewer window(without any error).
I checked with manual, it says for r theta profile, it has to be structured in proper style of increasing theta order. But I have x-y profile, which I imposed directly. (see attached)
Just for your information, when i impose constant value as initial guess, the solver starts but exits with negative pressure and density.
I have attached the message snapshot.
I think the error is in the initial solution menu, as error message says, not at inlet implementation.
Thanks alot!!
Kind Regards
Vishwas
Old   April 21, 2018, 15:19
Holger Dietrich
Dear Vishwas,
in one of the FINE/Turbo tutorials (Aachen turbine) you have to define an inlet boundary profile (1D) as function of r. Often beginners forget to switch from "function of x" (default) to "function of r". In this case the same error message appears, mentioning an issue about the turbo machinery initialization. The real reason is that a "profile along x" is simply not supported as boundary condition.
It might be the solution to convert the X-Y coordinates to r-theta coordinates. You can do a test with a simplified profile just to check if this will work.
Kind regards,
Holger
Old   April 21, 2018, 16:18
Vishwas Verma
Dear Holger,
I have tried a simple pressure profile of the r-theta and pressure value. In this profile I have given 12 theta position. For each theta, r and p values are defined. I have attached the file, which I am using for input(for sake of uploading i have changed extension to .txt from .p).
I still get the same error. This time it says r-theta error instead x-y.(attached).
I am not sure why does it says error in initial solution.
Thanks!!
Kind Regards
Vishwas
Old   April 21, 2018, 17:33
Holger Dietrich
Dear Vishwas,
the combination 2D profile with turbo machinery initialisation doesn't seem to work independent of the chosen variables (just did a short test case on my side), just as stated in the manual.
But in my case the computation starts successfully with a 2D profile (Total Pressure at inlet, r-theta) when using "constant values" instead of turbo machinery initialization. Could you check that again, maybe you forgot to save the .run file after you changed the initialization to "constant values"?
Kind regards,
Holger
Old   April 26, 2018, 11:59
Vishwas Verma
Dear Holger,
Thanks alot.
It does work as you have stated. In my case some issue was coming with constant initial solution. So to get rid of this, i ran a case with uniform inlet flow and generated an initial solution. With this solution, i initialized profile cases and it works fine.
Just for the information, xy profile also works good.
Many Thanks!!
Kind Regards
Vishwas
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 17:45
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
