Home > Forums > Software User Forums > Fidelity CFD
Secondary inlet
Old   May 6, 2011, 01:28
Default Secondary inlet
Martin
Martin_D is on a distinguished road
Grettings,
I'm simulating a flow over an airfoil that has a secondary inlet so the flow from the secondary inlet exits at the trailing edge of the airfoil. The problem is that when airflow is coming in the domain from both inlets the solver either crashes or the solution does not converge. Simulations have been made with only the primary inlet and were good but as soon as the secondary inlet becomes involved I can't seem to get any kind of solution. The boundary conditions at both inlets are defined as mass flow. Outlet is defined as static pressure imposed.
Can anyone hep me with this matter or give me an advice?
Martin_D is offline   Reply With Quote
Old   May 9, 2011, 05:39
Martin
After changing the boundary conditions of the main inlet and outlet to EXTERNAL (secondary inlet stay the same- mass flow imposed) I got a converged solution for a steady simulation but I'm still not able to get an unsteady solution.
Old   May 15, 2011, 00:00
Hamid Zoka
Hamidzoka is on a distinguished road
Dear Martin
what is your initial solution when you solving unsteady model?
did you check the delta t? maybe it needs to be reduced.
Hamidzoka is offline   Reply With Quote
Old   May 16, 2011, 03:39
Martin
My initial solution was a steady Spalart-Almaras solution and then a SST steady solution.
I have tried changing the physical timestep, at first it was 0.001 and when I changed it at 0.005 it actually worked but the convergence was poor. It's is a bit confussing.
I've noticed that the solver is very sensitive when applying different initial solutions and boundary conditions.
Old   May 23, 2011, 08:33
Martin
When I run an unsteady SST simulation with a timestep of 0.006 the solver does the job but when I lower the timestep to 0.001 or 0.0001 seconds then the solver calculates a negative pressure and crashes. Can anyone help me with this matter?
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 10:22
Furnace Secondary Air Inlet Amanda FLUENT 1 May 22, 2007 08:31
How much the value of secondary phase at the inlet KBS FLUENT 2 May 31, 2006 10:18
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
