Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Multiple surface selction in FloEFD
Old   March 17, 2016, 10:08
Default Multiple surface selction in FloEFD
G.
AlgoaBay is on a distinguished road
Hi there,
I am trying to apply a surface source on die inner cavtity. Therefor I need to select quite a lot of little surfaces which are very hard to select by clicking each and every single on.
Is there a way to select multiple surfaces via polygon or rectengular drag courser in the FloEFD selction window?
Regards
AlgoaBay is offline   Reply With Quote
Old   March 18, 2016, 07:53
Snow360 is on a distinguished road
I don't know how to select multiple surfaces at once. But a useful feature for selecting specific surfaces is to right click and use "select other" button. There you can select the specific face you want.
Snow360 is offline   Reply With Quote
Old   March 21, 2016, 14:14
Sascha
freierfall is on a distinguished road
yes this is difficult. i cut the modell and mark every surface with one click. it is still fast with 100 surfaces.
there is also a function - there you can save a selection. But you still have to click it.
freierfall is offline   Reply With Quote
Old   March 22, 2016, 10:29
G.
Thank you guys anyway.
Yes its very difficult, haven't found a proper solution yet.
Old   March 23, 2016, 08:43
Disabled
Boris_M will become famous soon enough
If that isn't possible in the CAD system then it is also not possible in FloEFD/SWFS.
Depending on how many surfaces you have to select and how many you don't have to select, you can also try it the other way around and deselect the ones you don't need from all of the selected ones.
Boris
Boris_M is offline   Reply With Quote
surface seletion multiple
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Multiple domain interfaces on a single surface mike CFX 2 January 26, 2009 17:03
