May 23, 2020, 05:27 |
Help me! Non-stationary calculation aircraft
Sergey
Hi everyone!
Need help, pleease. Please tell me whether it is possible in FloEFD to simulate the descent of the device in the atmosphere with a change in atmospheric parameters in height. PS if it doesn’t complicate, describe as detailed as possible, I can’t understand how to solve the unsteady problem correctly |
June 30, 2020, 07:39 |
Disabled
Rep Power: 23 |
Hi Sergey,
Yes, it is possible. First of course you will need a transient project setting. Of course you will need to know the overall time of your descent and the height change over the time. You can then change the "thermodynamic parameters" in the Initial and ambient conditions of the Wizard/General settings to "Altitude". The parameters here are based on the standard atmosphere with a temperature deviation. You can then set the height as a dependency (see the button at the bottom) and select for example "F(time) -Table" where you can enter your data of the height over the time. Regards, Boris |
aerodynamic, aircraft design, condition missing, hypersonic flow, rocket |
Increase in CPU number during the FIRE calculation | amin_u50 | AVL FIRE | 0 | August 6, 2014 08:34 |
Calculation of initial k for RAS turbulence models | shipman | OpenFOAM | 1 | August 28, 2013 03:52 |
DICPCG calculation don't converge (interFoam) | Kaquesang | OpenFOAM Running, Solving & CFD | 0 | November 16, 2012 20:05 |
SITVC calculation | cfdzak | Main CFD Forum | 0 | July 18, 2012 02:50 |
[ICEM] Annoying mesh holes on an aircraft | Santos-Dumont | ANSYS Meshing & Geometry | 2 | March 2, 2012 08:13 |
