Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Modelling Loop Heat Pipe (effective thermal conductivity)
Old   July 17, 2023, 07:42
Default Modelling Loop Heat Pipe (effective thermal conductivity)
Joe
hajakala is on a distinguished road
Hello. I am a user of FloEFD, often modelling heat pipe and vapor chamber as a heat spreader by assigning an effective thermal conductivity, rather than trying to simulate the actual phase transformation.
I was wondering if anyone could give me an advice on how to model a loop heat pipe, where the structure is separated into liquid and vapor lines. In this case, how can I model it using effective thermal conductivity? Or is there any other method of modelling the loop heat pipe?
Thanks for your help.
hajakala is offline   Reply With Quote
Old   July 19, 2023, 09:25
Florian
native is on a distinguished road
Hello Joe
I didn't model heat pipes yet. But maybe could it be a possibility to model the loop heat pipe as an assembly. By using several parts fitted together in the assembly you could assign different effective thermal conductivities to these different parts.
Regards
Florian
native is offline   Reply With Quote
Thermal conductivity of pulsating heat pipe (PHP) Kuldeep Tolia FLUENT 0 September 24, 2020 07:03
Effective Thermal Conductivity Merlin CFX 2 July 23, 2015 08:10
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Porous Media Effective Thermal Conductivity Greg Perkins FLUENT 3 August 5, 2001 22:53
