June 11, 2013, 03:03 |
VFR (Q) boundary condition
morteza
Rep Power: 12 |
Hi all dears,
I want to use VFR boundary condition in my simulation. In fact i want to use a volume flow rate such as a pump to exit flow in my domain with distinct flow rate. could you pleas, how i can do it? |
June 12, 2013, 08:35 |
michael barkhudarov
Rep Power: 18 |
June 15, 2013, 01:22 |
morteza
Rep Power: 12 |
hi
flow-3D V.10.0.1 thank you |
July 14, 2013, 02:04 |
michael barkhudarov
Rep Power: 18 |
This can be done in two ways. Either a mesh BC or a mass sink. A mesh BC is simply defined at the mesh edge, choose VFR BC, set the flow rate, set the direction of the flow - done!
A mass sink is defined using a geometry component. Define the component (e.g., a disk), and set its flow rate to a negative value. Michael |
July 15, 2013, 02:03 |
morteza
Rep Power: 12 |
hi, prof. michael barkhudarov
thank you for your reply, but in VFR BC, you can only enter flow into domain not exit from domain. we can only determine direction of entering flow to domain not exiting flow from domain. |
July 15, 2013, 11:08 |
michael barkhudarov
Rep Power: 18 |
Not quite. While the flow rate is always positive, the direction of the flow is defined by the flow direction vector: positive - into the domain, negative - out of the domain.
July 16, 2013, 04:06 |
#7 | |
morteza
Rep Power: 12 |
Thank you for your reply, my problem solved. I have another question: It is possible to draw 2D streamline in flow3D, similar to 3D streamline? best wishes |
July 16, 2013, 18:38 |
michael barkhudarov
Rep Power: 18 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Opening Boundary Condition | andreachan | Main CFD Forum | 11 | March 19, 2013 16:46 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
