Home > Forums > Software User Forums > FLOW-3D
Transfering data from block to block
Like Tree1Likes
  • 1 Post By thunde47
Old   February 10, 2020, 05:53
Default Transfering data from block to block
Ysmn
elyasmin is on a distinguished road
I would like to create a mesh for a large dam in Flow 3D. Therefore, I would like to split the dam into parts and run them block by block. I mean the downstream of the first block will be the upstream of the second one. At the end both will be like runned together. Can I do this in Flow 3D and how?
Thank you in advance!
Yasemin
elyasmin is offline   Reply With Quote
Old   March 2, 2020, 15:22
thunde47
thunde47 is on a distinguished road
Yes, you can use multiple blocks. At the interface of the two-block information will be transferred automatically. People typically want to do this when they want to use different mesh sizes.
thunde47 is offline   Reply With Quote
Old   March 3, 2020, 07:41
Ysmn
Hi thunde47, thank you for your respond!
Do I need to add restart simulation or copy the simulation after running first block? Also, should I use continuative or grid overlay? How can I manage boundaries between blocks?
Thank you!
Old   April 2, 2020, 17:18
thunde47
You can use nested (overlay) blocks or multiple blocks next to each other. No need to worry about the inter-block boundary conditions. The code takes care of data transfer between the blocks through special interblock boundary conditions. You can run the simulation in one go, no need to restart.
Old   April 3, 2020, 04:21
Ysmn
Accually, I am new in Flow3D and I did not know how to ask it. However, I know now that what I am searching for is Immersed body condition and there are some ghost cells between blocks which transfer data and help to run blocks seperately. Do you know how to do it?
Thank you,
Yasemin
Old   April 10, 2020, 16:54
thunde47
Yes, you can activate the Immersed Boundary Method (IBM) in FLOW-3D.
Go to Numerics. Go to momentum-advection column. Activate the immersed boundary option.
elyasmin likes this.
Old   April 10, 2020, 20:13
Ysmn
Thank you for your answer but there is no IBM under Numerics Tab.
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 10:01
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
