Home > Forums > Software User Forums > FLOW-3D
Vortex-induced Vibration (VIV)
Like Tree1Likes
  • 1 Post By mali
Old   May 29, 2012, 19:41
Question Vortex-induced Vibration (VIV)
ariza
ariza is on a distinguished road
hai guys.
I was a student last semester. I am currently working on final project with the topic of large-diameter cylinder viv in force due to currents and wave forces. I'm using a flow-3d for the simulation of vortex shedding. but until now I can not how.
whether there are any of you guys can help me? provide solutions or suggestions how?
thanks for the help.
ariza is offline   Reply With Quote
Old   August 6, 2012, 01:16
hans_ina is on a distinguished road
Originally Posted by ariza View Post
hai guys.
Hi Ariza,
what you mean of VIV is vibration due current around cylinder?
can you specified your question about? its your problem on modelling or meshing or else? please specified.
Thanks,
Hans
hans_ina is offline   Reply With Quote
Old   August 6, 2012, 20:11
ariza
In my Case,
VIV occurs because the combination of currents and waves.
then, how steps to make simulation with Flow3D?
such as modelling, input, solution, output...
thx for your attention...
Old   August 6, 2012, 21:23
For modeling, you can input the parameter (read manual handbook) then fill the BC with inlet and outlet as outflow.
Put the parameter and fill current and wave value (note: use free surface for input wave value)
hope this helpfull for your thesis.
Old   August 6, 2012, 22:46
ariza
thx a lot..
now i've finished my final exam..
23 september is my graduation..
Old   October 24, 2012, 10:41
hossein
hossein2357 is on a distinguished road
hi, i dont underestand"read manual handbook"
which handbook?
hossein2357 is offline   Reply With Quote
Old   October 24, 2012, 11:28
hossein
i simulated cylindric in sea. but i dont know, how i can obtain "vortex" .
'vortex induce vibrating'
Old   October 24, 2012, 21:32
which handbook?
You can find it on help menu guy.
Old   May 31, 2013, 00:11
mali is on a distinguished road
Hi All,
I think for simulating vortex induced vibration of a bluff body (exm: circular) can be done using the similar case of wingMotion in the tutorial. I had simulated a circular cylinder using pimpleDyMFoam, and it worked for small reduced velocity u* < 1, but it blowed up at higher reduced velocity. I suspected this happened because the system was in resonance, so the vibration was very high in amplitude, where I can saw the mesh changed badly at that time.
If you have suggestion on how I can simulate the VIV problem for high reduced velocity, please let me know.
Cheers
-mali-
mali
mali is offline   Reply With Quote
Old   May 31, 2013, 06:29
Originally Posted by mali View Post
Hi All,
Cheers
-mali-
what case you study?
Old   June 1, 2013, 00:25
Hi hans_ina,
Thanks for your replay.
I used 2D rigid circular cylinder attached with a vertical spring. Re based on diameter of the cylinder was in the range of 3000 to 22000, depending on the value of reduced velocity. For the elastic system, the mass ratio was 2.4 and the damping ratio is 0.0054 , similar to the case of Khalak and Williamson [1996].
Cheers,
SJTU likes this.
mali
Old   July 5, 2013, 08:42
Default damper
  #12
hossein
Hi friend
do you know, how can add damper for Cylinder in viv research or other work.
we want simulate moving object with damper, but we dont know how we can add damper to object.
Old   July 8, 2013, 09:58
Default 3D mesh
  #13
Mike
mikkysaik is on a distinguished road
Hi all. I am trying to model 3D flow around a cylinder using ANSYS fluent. I need info on how to generate a 3D mesh. I tried generating the geometry but got stuck. please I need info on how to go about it.
mikkysaik is offline   Reply With Quote
Old   December 13, 2018, 07:15
Thumbs up
  #14
jason
jjason is on a distinguished road
hai guys.
Hi Ariza
Could you please tell me that how to combine the wave and current by using flow3d?
Thanks very much,
JJason
jjason is offline   Reply With Quote
Old   December 13, 2018, 09:46
jason
jason_sjtu is on a distinguished road
hai guys.
Hi, I did get the vortex behind a cylinder. My Ur=1~7, or something. it's too long to remember.
my parameters are U_infinite=1, R=1, rho_fluid=1, mu and the spring coefficient are calculated from a few equations.
More importantly, the density and the spring coefficient are the most important.
the simulating time may be 100~700 second, varying according to Ur.
jason_sjtu is offline   Reply With Quote
Old   December 7, 2020, 11:51
Erfan785 is on a distinguished road
Hi hans_ina,
Cheers,
can you send me a tutorial about how to simulate this case, please?
Erfan785 is offline   Reply With Quote
vortex induced vibration Simon Wang FLUENT 4 December 25, 2017 03:23
vortex induced vibration from dynamic mesh natto Main CFD Forum 4 April 18, 2015 19:42
Vortex Induced Vibration (VIV) modelling Kwong FLUENT 1 December 1, 2009 13:08
Vortex Induced Vibration modelling Kwong FLUENT 0 March 24, 2007 00:41
Vortex Induced vibration of subsea pipeline Mobasheri FLUENT 5 February 9, 2006 07:07
