Home > Forums > Software User Forums > FLOW-3D
Moving Radial Gate
Old   January 10, 2021, 09:21
Exclamation Moving Radial Gate
Adil Javed
adilch is on a distinguished road
Hi there, I am modeling a Barrage Weir in flow-3d. Without radial gate model is working perfectly. But now I want to introduce a movable radial gate with a speed of 6in/30sec. How can I achieve it? I have added a moving and simple deforming model and I am not sure how to use it. can someone please elaborate on how to do it. thanks
adilch is offline   Reply With Quote
Old   January 10, 2021, 18:11
Eric Lemont
Flow Science Australasia is on a distinguished road
In the geometry tab, select your gate component and adjust the moving object properties. You'll want your gate component to be a separate component.
When your gate component is selected, look in the Moving Object Properties and you'll want to make the moving object type a prescribed motion (look in the component properties window below the components).
Then edit the properties to be a rotation about a fixed axis and define your coordinates of the axis. Then prescribe the angular velocity in the initial/prescribed velocities tab.
Flow Science Australasia is offline   Reply With Quote
moving body, radial gate
Radial Gate Movement MSM1985 FLOW-3D 6 May 20, 2020 14:13
[Other] simulation of closing the gate using moving mesh simin_ds OpenFOAM Meshing & Mesh Conversion 8 April 12, 2019 05:49
How to model radial gate motion in a hydraulic structure Babar FLOW-3D 0 July 6, 2017 03:38
Making grids for the model containing a moving gate saatt OpenFOAM Running, Solving & CFD 0 March 21, 2017 20:03
moving gate in conduit student-1 FLUENT 0 July 5, 2011 10:35
