Home > Forums > Software User Forums > FLOW-3D
Which features to model hydraulic structures?
Old   March 10, 2012, 01:34
Default Which features to model hydraulic structures?
bbayat is on a distinguished road
Dear users
I am going to model some hydraulic structures such as spillway, bottom outlet, flip bucket, stilling basin, flow near sluice gates, ... which contain water and air mixtures in some flow regions; or maybe we have some aerator from an opening.
It would be so appreciable that someone tells me if I should consider any of the following features in my models:
1- air entrainment model,
2- two phase fluid (water+air)
3- bubble and phase change model
4- cavitation model
5- Density evaluation
Thanks a lot
bbayat is offline   Reply With Quote
Old   March 13, 2012, 14:55
Jeff Burnham
JBurnham is on a distinguished road
if the air is entrained at a free surface or can escape, then
1) air entrainment
2) density evaluation
3) drift-flux (use water viscosity for 'two-fluid mixture' viscosity, and ~0.95 for drag coefficient).
don't use cavitation model for your case.
JBurnham is offline   Reply With Quote
Old   March 14, 2012, 08:35
Dear Jeff
Thanks for your reply.
Now that I found which models to activate, I have some more detailed questions and I would be happy if you could help:
- Air entrainment model
Does "entrainment rate coefficient" mean Qair/Qwater ?
What should we consider for "surface tension coef."?
which option to use is better?
How about fluid tab?
Should I change: Fluids> water at 20> edit> phase change> solidifaction fluid1 properties> density value to density of air? [Floscience: FSI-03-TN61]
How about Viscosity and turbulence?
If I use RNG, can I let "Turbulent mixing length" value empty? If not what is a rule of thumb for its value?
How about modeling areators?
If we know the Q(air) from an aerator from a specific location, how can we model it?
I do apologize, making so many questions.
Old   March 14, 2012, 10:37
Jeff Burnham
Most of those questions can be answered from the User Manual or a quick Google search. As to how to add air at a known flow rate from an aerator, use a mass source or mass/momentum source and specify the density at the source as that of air (see the User Manual for descriptions of these options).
The entrainment rate coefficient is a scaling coefficient and is described in the Turbulent Air Entrainment at Free Surfaces tech note. Do not use the air entrainment model unless you are seeking to model air entrainment at free surfaces (i.e., only use density eval and drift-flux if you are only adding air at a known flow rate from an aerator). Good luck.
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 04:43
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 09:10
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
