Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Moving a trimtab at the water's edge (free surface)
Old   January 26, 2014, 16:04
Default Moving a trimtab at the water's edge (free surface)
Navid
navid65 is on a distinguished road
Send a message via Yahoo to navid65
3D schematic model showed in pic
help me to Descripted Bonudary Conditions and meshing model.
I thank you ahead for your help.
navid65 is offline   Reply With Quote
Old   January 27, 2014, 05:39
ram_call's Avatar
ram
ram_call is on a distinguished road
u can break B.C 2 and B.C 4 in to two boundaries while define them in Gambit. So u can handle better while air and water are separated. Then for water u can choose mass flow inlet and out flow, and for air u can choose both of them pressure outlet in the left and right side.
I'm here for more comments of others.
TNX
ram_call is offline   Reply With Quote
Old   January 27, 2014, 08:45
Navid
This pic showed my model whitout mesh.
but
The model meshed showed in pic.
Mesh around an obstacle with a high density that quad/tri used for mesh surface. and other surface used quad(map).
Is it OK?
what is mesh model better?
free surface, multiphase, transient, trimtab
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
Free surface moving boundary zou_mo OpenFOAM Running, Solving & CFD 3 December 28, 2005 20:33
free surface display carno Siemens 4 October 7, 2005 01:03
Free surface and moving body Steve Siemens 4 August 20, 2004 11:06
