Heat transfer problem in a two phase eulerian fluidized bed |
July 26, 2016, 17:37 |
Rep Power: 9 |
Hi everybody, I am working on a project on the modeling of a fluidized bed for feedstock gasification using the eulerian model on Fluent.
I implemented the reactions in the model (gasification and combustion) which seem to work fine and I can observe the endothermic behavior of the gasification processes and the exothermic one for the combustion processes. My problem is : without any heat transfer between the solid and gas phase, the temperature increase around 1500K when there is combustion in the reactor. As soon as I turn on any heat transfer model between the two phases, say the Gunn model for example, there is almost no temperature increase with the same problem setting as before. I know I have to model heat transfer in some way between the two phases but at the same time I would hope to see a significant temperature increase due to combustion. I have to finish my project soon, so any help would be very appreciated! Thank you |
August 24, 2018, 08:26 |
Gunn Model Heating
Emerson
Rep Power: 7 |
Hello, I do have the same problem. In my case, there is a gas phase at 2100 °C that is supposed to heat a granular phase, but there is not an increase in the temperature of the granular phase. I am using the Gunn model too. =/
December 15, 2018, 06:50 |
Fluidized bed simulation
Hooman
Rep Power: 7 |
Hi my friends,
I am trying to simulate a thing like a fluidized by Fluent, I used the Eulerian model. My problem is as you can see in the figure some particles extract from bed and goes to outer, How can I fix this problem? Last edited by newton2009; December 16, 2018 at 05:30. |
combustion, eulerian, gasification, multiphase, reactor |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | Main CFD Forum | 1 | February 19, 2019 02:11 |
Heat Transfer in Fluidized Bed | brams | FLUENT | 0 | June 12, 2016 02:12 |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | CFX | 1 | January 29, 2012 17:48 |
Conjugate heat transfer problem | hvem10 | FLUENT | 2 | October 29, 2009 17:31 |
