June 5, 2018, 04:36 |
Two domains with different flow conditions
Gasim
Rep Power: 7 |
Hello
Is it possible to simulate two fluids flow at different conditions? the problem consists of " a vertical pipe in a rectangular tank, the fluid in the pipe is pressurized, so, it is a single phase flow. the tank is at atmospheric pressure and tow phase flow." When I used multi-phase model, it has been set for both domains. How can I set single phase model for a domain and two phase model for another one? also, How can I set different operating pressures for each domain? |
June 5, 2018, 04:46 |
Gasim
Rep Power: 7 |
Note that the two fluids are different.
June 6, 2018, 08:19 |
Cees Haringa
I have a bit of an issue figuring how you establish a pressure jump between your pipe and tank - at least, I assume these two are connected, right?
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) | Juun | FLUENT | 1 | November 19, 2023 01:06 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Boundary Conditions for Supersonic Flow | wididid | OpenFOAM Running, Solving & CFD | 5 | August 17, 2017 01:17 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
