October 25, 2021, 04:17 |
regarding biomass gasification.
Aravind
Rep Power: 6 |
Hello everyone,
I am doing my thesis on biomass gasification. I am using the Euler-Euler method to simulate the gasification and my model description is below. Multiphase Primary phase - gases that participate in the homogenous reaction. Secondary phase - biomass (granular) Dia - 0.0005m Drag model - symalal Heat transfer between primary and secondary phase - gunn. Secondary phase - sand (granular) Dia- 0.0003m Drag model - symalal Heat transfer between primary and secondary phase - gunn. Interfacial area between primary and secondary phases - ia-particle. between secondary phases - ia-particle. turbulence K-Epsilon- dispersed Standard wall function Reactions volumetric - Finite rate / eddy dissipation. 3 homogenous reactions and 5 heterogeneous reactions. Boundary conditions Biomass - mass flow inlet - 0.012kg/s @ 800k Primary air - velocity inlet - 0.035 m/s @ 800k Secondary air - velocity inlet - 0.015 m/s @ 800k outlet - pressure outlet wall - no slip for both primary and secondary phases. Methods pressure velocity coupling - phase coupled SIMPLE Gradient- Least square cell-based. pressure - second order momentum, volume fraction, turbulent kinetic energy, dissipation etc - first order. initialization Standard initialisation with every phase at room temperature without sand bed. calculation step size - 0.1 (the large step is due to No. of iteration - 30 I have first initialized without sand bed with the above-mentioned conditions and ran the simulation for 25 seconds physical time step for the development of combustion. the combustion reactions happened at the bottom of the reactor. Problems when I patch the sand bed with the volume fraction of 0.6 and up to 200mm from the bottom of the reactor the temperature of the bottom gradually reduces to inlet temperature i.e 800k. But according to results from the experiment, the reactions happen at the bottom (high temperature) and the top of the reactor should be at low temperature. But in my case after introducing sand bed it happens vice versa. Most of the temperature is near the secondary inlet. Qestions How to overcome this phase interaction problem? What is the heat transfer mechanism between two granular secondary phases? because the heat transfer between primary and secondary phases are defined by Gunn. But I can't able to find the heat transfer mechanism between two granular secondary phases in Ansys fluent guide. I have attached images of the reactor. Thank you for your supports and have a nice day. |
biomass gasification, euler euler solid-gas, multiphase mixture model |
Problems with Biomass Gasification | Chalumpol | FLUENT | 1 | August 29, 2017 03:57 |
Biomass gasification model: floating point error | Jamiebell94 | STAR-CCM+ | 0 | December 3, 2016 15:18 |
Four-way coupling simulation of coal combustion or biomass gasification | Shuai_W | OpenFOAM Programming & Development | 2 | October 26, 2016 04:28 |
udf for biomass plasma gasification | xlwmoaggouri | Fluent UDF and Scheme Programming | 0 | January 10, 2014 14:45 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
