Mass source UDF
Like Tree1Likes
  • 1 Post By Abhya
Old   January 21, 2013, 00:17
Default Mass source UDF
Ernesto
epc1 is on a distinguished road
Hello:
I´m trying to make a UDF to define a mass source term for the continuity equation that includes the net production of mass(or destruction due to chemical reactions)) in my problem. The reactions are included in the reaction panel, and the rates are modified via another udf. I know that it is not necessary to include the overall source term in the continuity equation, since the overall production of mass due to the reactions is zero.
Is there a way to access the rates defined in my other udf to formulate the mass source udf? I have tried via the extern variables, however when i set a memory to monitor the value of the mass source term, it appears that it´s not taking the correct value.
Another thing is that the fluent user guide mentions that if you create a mass source term, you also have to create a momentum, and energy source term. Would that still be neccesary in this case?
Thanks in advance.
epc1 is offline   Reply With Quote
Old   January 24, 2013, 09:24
Abhya is on a distinguished road
whether u have to define a source term for momentum or energy equation depends on the function u use. eg: define_mass_transfer doesnt need mom,energy source terms separately if u define mas term...but define_source does req.. as far as i remember..Im a noob to this btw
check out the user manual for the specific function in udf u r using
hane likes this.
Abhya is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
