Scheme command for volume-average value
Like Tree2Likes
  • 1 Post By macfly
  • 1 Post By cicatrix
Old   May 26, 2014, 22:54
Default Scheme command for volume-average value
Jemyung Cha
cicatrix is on a distinguished road
Hi guys.
I am doing some works about monitoring and changing boundary conditions
with scheme language.
I already know how to get area-weighted-avg temperature like below.
These two TUI commands are same. One is scheme and another one is journal command.
(define check_temp (surface-area-average (list (surface-name->id thermostat)) "temperature"))
;; Scheme command
/report/surface-integrals/area-weighted-avg thermostat () temperature ,
;; Journal command
But, I do not know how to get volume-average temperature and heat source value in specific cell zone with scheme.
Is there a anybody who can help me?
cicatrix is offline   Reply With Quote
Old   May 27, 2014, 04:52
pakk will become famous soon enough
I looked at the User manual, Fluent Text Command list.
You already found "/report/surface-integrals/area-weighted-avg"
But now you don't want a surface integral but a volume integral, so I looked further:
volume-integrals/
Enter the volume integral menu.
volume-avg
Print volume-weighted average of scalar over cell zones.
So the journal command you are looking for is "/report/volume-integrals/volume-avg".
pakk is offline   Reply With Quote
Old   May 27, 2014, 10:09
Jemyung Cha
Thanks for your helpful explanation.
But I need to know scheme commands to make some codes which can control temperature and source term.
Old   May 27, 2014, 11:11
You can turn every journal command into a scheme command by using "(ti-menu-load-string ...)"
So in this case:
(ti-menu-load-string "//report/volume-integrals/volume-avg volumename temperature")
Old   May 27, 2014, 19:37
Jemyung Cha
I know (ti-menu-load-string ...) can do measure volumename's temperature.
But I need to store variables in memory using the scheme commands.
(ti-menu-load-string ...) can just returen #f or #t.
Old   May 28, 2014, 02:09
OK, you didn't mention yet that you wanted to use the value, and not just print it.
I now understand your problem, but don't know the solution. I am interested to know the answer, though...
Old   November 12, 2014, 20:48
Younis Najim
Heat80 is on a distinguished road
Originally Posted by cicatrix View Post
Hi guys.
;; Scheme command
;; Journal command
(ti-menu-load-string (format #f "report volume-int va thermostat () temperature yes yourfilename yes"))
Hopefully not too late
Heat80 is online now   Reply With Quote
Old   November 12, 2014, 20:52
François Grégoire
macfly is on a distinguished road
probably volume-average instead of volume-int
Heat80 likes this.
macfly is offline   Reply With Quote
Old   November 15, 2014, 21:35
Younis Najim
You right. You can also divide the volume integral result by domain volume as another way to get the average value over the domain.
Old   November 20, 2014, 07:53
Jemyung Cha
I solved with follwing scheme commands.
(%fill-node-values 'temperature)
(define Temp_A (%volume-integrals 'volume-average '(Cell Zone ID) "temperature"))
;; Temp_A is a variable name what you want to make
;; You can get Cell Zone ID in cell zone conditions in flunet window.
Heat80 likes this.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? rsin CFX 19 December 29, 2018 04:43
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
