why I cannot get the correct x and y values when using UDF? |
January 21, 2015, 23:54 |
Haoting Wang
Rep Power: 11 |
Hi everybody,
I am trying to use UDF to do some control of my fluid field. By judging the temperature of some cells, the inlet velocity is changed. I tried to use the method in this link http://www.cfd-online.com/Forums/flu...ure-point.html But I found that I can't even get the correct x and y values of the cell centroid. Here are some values I got from my code: x: -536870912 y: -1610612736 x: -1610612736 y: -1610612736 x: 1610612736 y: 536870912 x: -536870912 y: 0 x: 1610612736 y: 536870912 thermocouple temperature is: 0 nt: 0 ND_ND: 2 The following is my code, I really don't know what is wrong. Please help me if you can, thank you! #include "udf.h" #define upTemp 298 #define lowTemp 296 DEFINE_EXECUTE_AT_END(tsensor) { real thermosensor_coordinate[ND_ND]; real thermosensor_temperature; real xmin; real xmax; real ymin; real ymax; real x=1,y=1,nt; cell_t c; Domain *d; Thread *t; d = Get_Domain(1); /*get domain id, single phase is 1*/ xmin=0.24; xmax=0.25; ymin=-0.01; ymax=0.01; /* Begin loop to determine the temperature at the centroid of cells near the thermocouple */ thread_loop_c(t,d) { nt=0.0; begin_c_loop(c,t) { C_CENTROID(thermosensor_coordinate,c,t); x=thermosensor_coordinate[0]; y=thermosensor_coordinate[1]; if ((x >= xmin) && (x <= xmax)) { if ((y >= ymin) && (y <= ymax)) { thermosensor_temperature=thermosensor_temperature + C_T(c,t); /* get thermocouple temperature */ nt=nt+1.0; /* count number */ printf("x: %d\n", x); printf("y: %d\n", y); } } } end_c_loop(c,t) } thermosensor_temperature=thermosensor_temperature/nt; printf("thermocouple temperature is: %d\n", thermosensor_temperature); printf("nt: %d\n", nt); printf("ND_ND: %d\n", ND_ND); } DEFINE_PROFILE(inlet_V,t,i) { real thermosensor_temperature; face_t f; if (thermosensor_temperature>=upTemp) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = 1.38; } end_f_loop(f,t) } else if (thermosensor_temperature<lowTemp) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = 0; } end_f_loop(f,t) } } |
January 22, 2015, 05:03 |
Rep Power: 12 |
Don't you see anything strange in your coordinates?
For example, your "y" coordinate:-1610612736. The distance from the Earth to the Moon is 384000000 m , so your device is 4 times further from your origin of coordinates than the Moon from the Earth, think about it. No big deal actually, in your message printf("x: %d\n", x); "x" is real, and "%d" means integer, change you "%d" for a "%g" or "%f" and everything will be fine. Your question is an old issue in this forum: http://www.cfd-online.com/Forums/flu...t-problem.html I have tried this function but it did not work. The solution given in the post you mention is easier and pretty accurate. It set a tolerance margins from your coordinates and it looks for a cell nearby. Cheers. |
January 22, 2015, 07:46 |
Rick
Rep Power: 26 |
Moreover, I think you will get an error (or something strange) if upTemp<=thermosensor_temperature<lowTemp
Write a condition to define a profile when thermosensor_temperature is in this range. And moreover (2) thermosensor temperature must be a global variable: see here: http://www.cfd-online.com/Forums/flu...tml#post514940
Google is your friend and the same for the search button! |
January 22, 2015, 10:21 |
#4 | |
Haoting Wang
Rep Power: 11 |
Thank you so much, I am not very familiar with c.
January 22, 2015, 10:32 |
#5 | |
Haoting Wang
Rep Power: 11 |
Thanks for your advice! I changed the sensor temperature to be a global variable. Now I can see them, but I am not quite sure why my "Execute_At_End" function looped 5 times when I run it. The results look like this:
nt outside loop: 0 thermocouple temperature is: 0.000000 ND_ND: 2 x: 0.245169 y: -0.000502 nt: 1 x: 0.245170 y: 0.000497 nt: 2 nt outside loop: 0 thermocouple temperature is: 593.720703 ND_ND: 2 nt outside loop: 0 thermocouple temperature is: 0.000000 ND_ND: 2 nt outside loop: 0 thermocouple temperature is: 0.000000 ND_ND: 2 nt outside loop: 0 thermocouple temperature is: 0.000000 ND_ND: 2 As you can see, during the first time loop, the code get the temperature and locations of the thermocouple point. But after that it loops 4 more times and covered the correct result. So weird. The code I used looks like this: #include "udf.h" #define upTemp 298 #define lowTemp 296 real thermosensor_T; DEFINE_EXECUTE_AT_END(tsensor) { real thermosensor_coordinate[ND_ND]; real thermosensor_temperature; real xmin; real xmax; real ymin; real ymax; real x=1,y=1; int nt; cell_t c; Domain *d; Thread *t; d = Get_Domain(1); /*get domain id, single phase is 1*/ xmin=0.2449; xmax=0.2453; ymin=-0.001; ymax=0.001; /* Begin loop to determine the temperature at the centroid of cells near the thermocouple */ thread_loop_c(t,d) { nt=0; begin_c_loop(c,t) { C_CENTROID(thermosensor_coordinate,c,t); x=thermosensor_coordinate[0]; y=thermosensor_coordinate[1]; if ((x >= xmin) && (x <= xmax)) { if ((y >= ymin) && (y <= ymax)) { thermosensor_temperature=thermosensor_temperature + C_T(c,t); /* get thermocouple temperature */ nt=nt+1; /* count number */ printf("x: %f\n", x); printf("y: %f\n", y); printf("nt: %d\n", nt); } } } end_c_loop(c,t) } //thermosensor_temperature=thermosensor_temperature/nt; thermosensor_T=thermosensor_temperature; printf("nt outside loop: %d\n", nt); printf("thermocouple temperature is: %f\n", thermosensor_temperature); printf("ND_ND: %d\n", ND_ND); } DEFINE_PROFILE(inlet_V,t,i) { face_t f; if (thermosensor_T>=upTemp) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = 1.38; } end_f_loop(f,t) } else if (thermosensor_T<lowTemp) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = 0; } end_f_loop(f,t) } } Quote:
January 22, 2015, 10:43 |
Rick
Rep Power: 26 |
Are you running in parallel?
January 22, 2015, 11:11 |
Haoting Wang
Rep Power: 11 |
I have five zones, 4 are solid zones, 1 is fluid zone. Does that have something to do with the 5 execution thing? If so, how can I modify my code to let it only execute on the fluid zone?
January 22, 2015, 11:12 |
Rick
Rep Power: 26 |
I think this has nothing to do with the 5 zones: are you running your simulation in parallel (with 4 processes)?
January 22, 2015, 11:14 |
#9 |
Haoting Wang
Rep Power: 11 |
January 22, 2015, 11:18 |
#10 |
Haoting Wang
Rep Power: 11 |
January 22, 2015, 11:22 |
#11 |
Rick
Rep Power: 26 |
Ok, the udf above should work for a serial run.
If you want to parallelize the udf you must include some more code, read here: http://www33.zippyshare.com/v/tsx9Z5Rk/file.html If you want to run in parallel: DEFINE_PROFILE macro will work as it is and it doesn't need to be parallelized, you need to parallelize the DEFINE_EXECUTE_AT_END macro. PS: you still need to add a condtion when temperature is 296<T<298
January 22, 2015, 15:57 |
#12 |
Haoting Wang
Rep Power: 11 |
Is there anyway that a part of code is only performed on ONE node? I tried to use if (myid=0), it is very strange that the loop still goes 5 times instead of only once. Here are the results and code:
nt2: 8 nt2: 0 nt2: 0 nt2: 0 nt2: 0 nt outside loop2: 0 I am node 0 with thermocouple temperature: 1.#INF00 #include "udf.h" #define upTemp 298 #define lowTemp 296 real thermosensor_T; DEFINE_EXECUTE_AT_END(tsensor) { real thermosensor_coordinate[ND_ND]; real thermosensor_temperature; real xmin; real xmax; real ymin; real ymax; int nt; real x=1,y=1; cell_t c; Domain *d; Thread *t; d = Get_Domain(1); /*get domain id, single phase is 1*/ xmin=0.2449; //0.2449; xmax=0.2455; //0.2453; ymin=-0.002; //-0.001; ymax=0.002; //0.001; /* Begin loop to determine the temperature at the centroid of cells near the thermocouple */ if (myid==0) { thread_loop_c(t,d) { nt=0; begin_c_loop(c,t) { C_CENTROID(thermosensor_coordinate,c,t); x=thermosensor_coordinate[0]; y=thermosensor_coordinate[1]; if ((x >= xmin) && (x <= xmax)) { if ((y >= ymin) && (y <= ymax)) { thermosensor_temperature=thermosensor_temperature + C_T(c,t); /* get thermocouple temperature */ nt=nt+1; /* count number */ printf("x: %f\n", x); printf("y: %f\n", y); printf("nt1: %d\n", nt); printf("I am node %d with thermocouple temperature: %f\n", myid, thermosensor_temperature); } } } end_c_loop(c,t) printf("nt2: %d\n", nt); thermosensor_T=thermosensor_temperature/nt; } printf("nt outside loop2: %d\n", nt); printf("I am node %d with thermocouple temperature: %f\n", myid, thermosensor_T); } } DEFINE_PROFILE(inlet_V,t,i) { face_t f; if (thermosensor_T>=upTemp) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = 1.38; } end_f_loop(f,t) } else if (thermosensor_T<lowTemp) { begin_f_loop(f,t) { F_PROFILE(f,t,i) = 0; } end_f_loop(f,t) } } |
January 22, 2015, 15:58 |
#13 |
Haoting Wang
Rep Power: 11 |
Does this has something to do with that I have five zones in my calculation domain? 4 of them are solid, 1 is fluid. But I have already used "d = Get_Domain(1)"
January 23, 2015, 06:06 |
#14 |
Rick
Rep Power: 26 |
Don't cross post as it is forbidden by forum rules, point 6:
http://www.cfd-online.com/Forums/misc.php?do=showrules Did you read the pdf I attached? It should look something like this: Code:
DEFINE_EXECUTE_AT_END(tsensor) { real thermosensor_coordinate[ND_ND]; real thermosensor_temperature; real xmin; real xmax; real ymin; real ymax; int nt; real x=1,y=1; cell_t c; Domain *d; Thread *t; d = Get_Domain(1); /*get domain id, single phase is 1*/ xmin=0.2449; //0.2449; xmax=0.2455; //0.2453; ymin=-0.002; //-0.001; ymax=0.002; //0.001; nt=0; thermosensor_temperature=0.0; /* Begin loop to determine the temperature at the centroid of cells near the thermocouple */ thread_loop_c(t,d) { #if !RP_HOST begin_c_loop_int(c,t) { C_CENTROID(thermosensor_coordinate,c,t); x=thermosensor_coordinate[0]; y=thermosensor_coordinate[1]; if ((x >= xmin) && (x <= xmax)) { if ((y >= ymin) && (y <= ymax)) { thermosensor_temperature=thermosensor_temperature + C_T(c,t); /* get thermocouple temperature */ nt=nt+1; /* count number */ } } } end_c_loop_int(c,t) #endif #if RP_NODE thermosensor_temperature=PRF_GRSUM1(thermosensor_temperature); nt=PRF_GISUM1(nt); #endif #if !RP_HOST thermosensor_T=thermosensor_temperature/nt; #endif node_to_host_real_2(thermosensor_temperature, thermosensor_T); node_to_host_int_1(nt); #if !RP_NODE printf("nt: %d\n", nt); printf("Thermocouple temperature: %f\n", thermosensor_T); #endif } }
Google is your friend and the same for the search button! Last edited by ghost82; January 23, 2015 at 12:02. |
January 24, 2015, 14:42 |
#15 | |
Haoting Wang
Rep Power: 11 |
yes, I've read it, thanks for sharing that to me. It is just that this code has some commands that can only be used if it is compiled. My computer has some problem in compiling the code, now I can only use by interpret.
Setting cell variable values in a fluid zone using UDF | eromon84 | Fluent UDF and Scheme Programming | 6 | March 28, 2021 11:59 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
Availability of previous time level values in UDF | ranga sudarsan | FLUENT | 0 | September 1, 2008 09:17 |
printing values from udf!!! | Shekhar | FLUENT | 2 | January 13, 2004 11:49 |
Printing Values From UDF | Pravesh Gangwar | FLUENT | 1 | October 22, 2002 06:08 |
