cell field variable for electric current density |
January 19, 2018, 15:12 |
RJC
Rep Power: 10 |
I need to write a UDF for a heat source which is a function of electric current.
What is the cell field variable for electric current density? I did not find anything in UDF manual. Thanks in advance. |
January 19, 2018, 15:42 |
RJC
Rep Power: 10 |
I have activated the electric potential model in fluent which allows me add joule heating and electric potential in the model. However, I need to add additional heat source which is a function of electric current. What I understand from fluent manual is that I need to write a UDF using the define_source macro. but to write my equation in that UDF, I need to know the cell field variable for current density which I did not find in the manual.
January 21, 2018, 20:17 |
Alexander
Rep Power: 34 |
If your are talking about Single-Potential Battery Model, you may find source for that model in fluent files, by default the path is:
C:\Program Files\ANSYS Inc\v182\fluent\fluent18.2.0\addons\battery\src in file battery.h you may find information about UDF variables: Code:
enum { CURRENT = 0, /* 0 */ CURR_X, CURR_Y, CURR_Z, CURR_M, /* Magnitude of current density vector */ OHMIC_SOURCE, ECHEM_SOURCE, ACTIVATION, DISCHARGE_DEPTH, U_FUNC, Y_FUNC, VOLTAGE_JUMP, RESIST_EFF, OTHER, NO_OF_UDMS /* 14 */ }; Best regards |
January 22, 2018, 13:13 |
RJC
Rep Power: 10 |
Thanks a lot for your reply.
I assume the UDM index of Battery module would be different from other modules. For my model, I either have to use the MHD module or the electric potential model available in fluent 17.2. Unfortunately, I could not find a similar .c or .h source file for MHD module in MHD module directory. |
July 3, 2018, 16:57 |
Paul Lee
Rep Power: 7 |
Did you find the cell variable for electric current density?
i'm writing a UDF for galvanic corrosion rate and would like to call the electric current for each cell to calculate the corrosion rate. and as a general question, is there a list somewhere the available cell variable one can retrieve using the "real" command? |
current density, potential electric, udf code |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Neighboring cells in tetrahedral mesh | vishwesh | OpenFOAM Programming & Development | 9 | November 10, 2017 07:06 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Implement simple barotropic relation - derive density field from pressure field | GJM1991 | OpenFOAM Programming & Development | 6 | May 8, 2016 15:43 |
