Wall Distance
Old   December 6, 2019, 05:56
Default Wall Distance
sufjanst is on a distinguished road
Hello everyone,
I am pretty new into UDF programming. I try to implement a model which is working with the cell wall distance. I can see the wall distance with a contour, but I can not use it in a UDF.
This is my example on how to save the wall distance as a user defined memory. I tried C_WALL_DISt and C_STORAGE_R which are both in the "mem.h"-file.
Here is my code:
#include "udf.h"
#include "mem.h"
DEFINE_ON_DEMAND(walldist)
Domain *d;
Thread *t;
cell_t c;
d = Get_Domain(1);
face_t f;
thread_loop_c(t,d)
begin_c_loop(c,t)
//C_UDMI(c,t,1) = C_STORAGE_R(c,t,SV_WALL_DIST);
//C_UDMI(c,t,2) = C_WALL_DIST(c,t);
end_c_loop(c,t)
Compilation works. But whenever I try to execute the function I get a Segmentation Error. Can someone tell me what the problem is?
sufjanst is offline   Reply With Quote
Old   December 8, 2019, 23:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
the code you've shared does nothing, so it cant generate any problems.
show the code you are using next time
code you need:
#include "udf.h"
Domain *d;
Thread *t;
cell_t c;
d = Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0) = C_WALL_DIST(c,t);
end_c_loop(c,t)
don't forget to allocate 1 udmi memory in Fluent GUI
-> user defined -> memory
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 9, 2019, 03:29
Of course I tried my code without comments, first with C_STORAGE_R and afterwards with C_WALL_DIST...
The code you shared, which is my code without comments, does not work.
User defined memory is allocated
Old   December 9, 2019, 22:52
Alexander
I have no experience in using C_WALL_DIST(c,t) macro
you may try following:
make a loop in fluid zone only,
turn on any turbulence model, make few iterations
after that run on_demand function
best regards
Export Minimium Wall distance AshwaniAssam Pointwise & Gridgen 1 March 22, 2019 15:42
Normal distance from a complex shaped wall - initial conditions prashantvalluri CFX 3 September 20, 2017 13:26
wall distance definition mostanad Main CFD Forum 12 July 25, 2017 11:20
Compute/Extract cell wall distance Ionut G Fluent UDF and Scheme Programming 0 March 23, 2017 07:05
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 10:24
