ANSYS: How to read Scheme file and change the boundary conditions
Old   May 29, 2021, 15:02
Post ANSYS: How to read Scheme file and change the boundary conditions
Betelhiem
Betelhiem is on a distinguished road
I am new to ANSYS and CFD. I was trying to change the boundary conditions of transient and Laminar simulation using a scheme file. The scheme file has properties such as inlet velocity and temperature. I have successfully imported the mashed geometry to the solver, and tried to read the scheme file using the step file > read > scheme, then choose my file. I can see that the scheme file goes through when the console shows me the message Done #f. But the problem is the boundary conditions are not changing even after reading the scheme file, I don’t know what its problem is. If anyone out there notices my mistake I would appreciate your help and suggestions.
Thank you very much!
Betelhiem
Betelhiem is offline   Reply With Quote
Old   May 30, 2021, 01:37
pakk will become famous soon enough
It sounds like you did OK, and the scheme file needs to be adjusted.
But, how can we tell without seeing the scheme file???
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   May 30, 2021, 20:08
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
copy first line of your scheme to fluent console, press enter
check, if it was executed according to your needs.
make it for the whole your code
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
