Multiphase Udf code for looping a wall face
Old   October 3, 2021, 01:39
Default Multiphase Udf code for looping a wall face
xingangzheng
ustbdynamic is on a distinguished road
Hello everyone!
During a multiphase flow simulation (air+sand, Eulerian-Eulerian model), I am trying to write an UDF to loop a wall face (its ID is 22). The purpose is to store some values (the secondary phase) of the wall adjacent cell to the UDM.
But after a long attempt, I failed to complete this process. The code is in vain for the wall adjacent cell. Those values that are not in this area are looped and stored instead.
There must be something wrong with my UDF,especially in the looping process.
I have no idea what to do next, so maybe someone here has an idea?
Thank you.
#include "udf.h"
#include "sg.h"
#include "sg_mphase.h"
#include "flow.h"
#include "mem.h"
#define ID 22 //WALL_NUMBER
DEFINE_ADJUST(settingvalue, mixture_domain)
Thread *cell_thread;
Thread *tc;
cell_t c;
face_t f;
Thread **pt;
Thread *ti;
Thread *tf;
mixture_domain = Get_Domain(1);
tf= Lookup_Thread(mixture_domain, ID); //getting the wall thread
mp_thread_loop_f(tf, mixture_domain, pt)
if (DOMAIN_ID(tf) == 3) // 3 is the secondary phase domain
begin_f_loop(f,tf)
tc = THREAD_T0(tf); /*adjacent cell thread*/
c = F_C0(f,tf); /*adjacent cell*/
ti = pt[1]; /* 0 pointer for the primary phase, 1 is for the secondary phase*/
C_UDMI(c,ti,0) = - C_R(c, ti)*C_VOF(c,ti)/CURRENT_TIMESTEP ;
end_f_loop(f,tf)
ustbdynamic is offline   Reply With Quote
Old   October 3, 2021, 02:26
pakk will become famous soon enough
I'm not sure if I understand this part. Do you mean that your UDF gives results for everything in your domain except the wall that you are interested in?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   October 3, 2021, 08:17
xingangzheng
Dear pakk.
Thank you for responding.
It may or may not be this. The contours in other areas show changes, but I am not sure whether it works well or not for everything except the wall that I am interested in. It is certain that it has no effect on the interested cells.
thank you.
Xingang
Old   October 3, 2021, 15:28
C_UDMI(c,ti,0)
Should be
C_UDMI(c,tc,0)
(i think)
Old   October 3, 2021, 21:14
xingangzheng
Thank you, I will try.
C_UDMI(c,ti,0)
Should be
C_UDMI(c,tc,0)
(i think)
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? Sorabh OpenFOAM Meshing & Mesh Conversion 1 August 3, 2021 06:35
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
Please check out my parallelized udf code aleisia Fluent UDF and Scheme Programming 0 June 10, 2011 16:16
