Error in compiling UDF
Old   March 7, 2011, 14:43
Exclamation Error in compiling UDF
akm
akm is on a distinguished road
Hello.
Im using some functions in my udf that can only be compiled and not interpreted. But i cannot compile my udf..
Im working on Win7 (32bit), Fluent 6.3.26. I have already installed Microsoft Visual Studio on my machine.
I have the source file (.c file) in the same directory as the the case and data files.
First, in the 'Compiled UDFs' panel, do i need to add 'udf.h' under 'Header files' tab ??
On hitting the 'Build' button, i am getting the following message on the console window:
Deleted old libudf\ntx86\2d\libudf.dll
The system cannot find the file specified.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2d\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2d")()
Done.
Can anyone pls help me and tell me what i need to do to compile a UDF..
Thanks.
akm is offline   Reply With Quote
Old   March 7, 2011, 15:12
Amir's Avatar
Amir
Amir is on a distinguished road
you didn't link Visual C++ with FLUENT.
headers can include automatically and you shouldn't care about.
Amir is offline   Reply With Quote
Old   March 7, 2011, 15:13
akm
Originally Posted by Amir View Post
and how can i do link them ??
Old   March 7, 2011, 16:10
Amir's Avatar
Amir
first you should include FLUENT to your environment by using this:
"~\Program Files\Fluent\ntbin\ntx86\setenv.exe"
for some versions of VC, libraries of VC were included to your environment while installing for these cases the above step is enough.
if your problem didn't resolved, you should also include VC libraries to your path and for this purpose you have 2 choices:
1) launch FLUENT from VC command prompt
2) refer to my blog in this forum to manually include VC libraries.
Regards,
Amir
Old   March 8, 2011, 03:34
akm
thanks Amir..
that problem was dealt with.
now there is a new one :
LINK : fatal error LNK1104: cannot open file 'kernel32.lib'
i see a lot of people hav this problem, but none of the solutions worked for me..
kindly help me out again.
thanks
Old   March 8, 2011, 10:06
Amir's Avatar
Amir
if you explain more, where and when you face that, I may help you.
Old   April 19, 2011, 04:56
Exclamation Define_adjust
akm
hey amir.. thanks for resolving my previous problem. i am afraid m facing a new one.
as i understand define_adjust can be "used to adjust or modify FLUENT
variables that are not passed as arguments".
in my 3phase eularian simulation i am required to modify the volume fractions of the two secondary phases, keeping the volume of primary phase same.
i have done the calculation as required in define_execute_at_end, to compute how much do the volume fractions change and hence correctly computed the value of global variables 'vf1' and 'vfpr'.
my adjust macro:
DEFINE_ADJUST(mt,d)
  Thread *t;
  cell_t c;
  real volf1, volf2, volf3;
  real xc[ND_ND];
  if (counter == 1)
    thread_loop_c(t,d)
      begin_c_loop(c,t)
         Thread *fr = THREAD_SUB_THREAD(t,1);  //1st secondary phase
	 Thread *to = THREAD_SUB_THREAD(t,2); //2nd secondary phase
	  volf1 = C_VOF(c,fr);
	  volf2 = C_VOF(c,to);
	  volf3 = 1-(volf1+volf2);  //primary phase volume frac.
	  if(volf1 > 0.01)
	    C_VOF(c,fr) = volf1 * vf1/vfpr;  //modifying the vol.fr. of 1st sec. phase
	    C_VOF(c,to) = 1-(volf1+volf3);  //adjusting the vol. fr. of 2nd sec. phase, keeping the sum of volume fractions unity.
	    C_CENTROID(xc,c,t);
	    Message("%g\t%g",xc[0],xc[1]);
	    Message("\t%g   %g\n",volf1,volf2);
      end_c_loop(c,t)
When the variables are printed from the udf, they do seem to get modified as required by the problem. But returning to solver at the end of iteration/timestep, the variables show no change when viewed as contours or even when accessed by define_execute_at_end macro.
What might be the problem in modifying the variables ??
Is there anything wrong in what i am trying to do? Please suggest an alternative.
Can you please help me..
Regards.
Old   April 19, 2011, 08:20
Amir's Avatar
Amir
if you want to do your desired modifications once, at the end of your calculation, I propose you to use another macro, DEFINE_ON_DEMAND, that may help you to implement your modifications when ever you want by executing this macro.
fluent compile udf error
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 18:05
compiling udf at window Nt(64BIT) noa FLUENT 3 July 29, 2014 23:01
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
