March 25, 2019, 10:32 |
Unusual Jump in Scaled Residual
Jay Vora
I am currently doing a 3D simulation for an aircraft. model- k-w sst steady-state pressure based solution Mesh Quality: Minimum Orthogonal Quality = 1.17479e-04 cell 796080 on zone 2 (ID: 1405101 on partition: 1) at location (-1.39139e+01 2.22699e+00 8.14461e+01) Boundary conditions velocity inlet pressure outlet Solution method Coupled and second order for the rest. During the solution phase, I get huge spikes in the calculation for both lift and drag force. also, a message is posted " Stabilizing pressure coupled to enhance linear solver robustness." - don't know what it means. I have attached images. Any help would be appreciated. |
March 25, 2019, 12:05 |
Lucky
Rep Power: 66 |
Yeah that's what happens when you have a bad mesh. Your minimum orthogonal quality is pretty bad. You might want to start there.
Also you can make a plot of pressure or velocity at a bunch of places and see if you can find where the problem is. It should be quite apparent. |
March 25, 2019, 12:31 |
Jay Vora
I tried improving the mesh quality. but it always gives the orthogonal quality as that. could you please suggest any way of improving the mesh quality?
March 26, 2019, 08:00 |
#4 | |
Lucky
Rep Power: 66 |
Bad meshes are often times a result of people being too smart for their own good.
You keep getting bad mesh because you are repeating the same bad habits when you create the mesh. Figure out what this bad habit is and stop it. Unfortunately it's hard to figure out from just a report what this bad habit is. Especially when I have no clue where the bad cells are. Quote:
Another suggestion that might take longer, mesh a very simple configuration like a box or a pipe so you can learn what are the key steps of meshing. |
pressure boundary, spikes |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
