Ansys + Fluent 2-way FSI coupling
Old   January 6, 2013, 05:02
Default Ansys + Fluent 2-way FSI coupling
raditz is on a distinguished road
Dear All
I am currently carrying out 2-way FSI coupling using ANSYS(14.5)+Fluent.
My test problem is a thin solid membrane located between 2 fluids.
I am stuck at the setup of the problem where I have to input the appropriate Dynamic Mesh settings with respect to smoothing and remeshing.
The outputs are one of the following
1)Check Mesh
2)Analysis settings are not valid
3)Not all participants and system coupling system have same analysis type.
I think the problem is either with the analysis settings with respect to time stepping or Dynamic Mesh Parameters or the Solver.
Any inputs and queries are welcome.
raditz is offline   Reply With Quote
Old   February 13, 2013, 15:47
stumpy is on a distinguished road
3) means that a static structural is connected to a transient Fluent, or visa-versa. Both need to be static/steady-state or both transient.
stumpy is offline   Reply With Quote
Old   February 14, 2013, 14:37
Thanks a lot for the input.I changed the solvers.
ansys 14 apdl
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
2way FSI Fluent Mechanical SETUP Problems MainzerKaiser ANSYS 7 May 20, 2016 11:22
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation Volker P. ANSYS Meshing & Geometry 22 January 17, 2012 17:27
error in two way fsi kmgraju CFX 1 May 2, 2011 02:32
