February 20, 2013, 18:04 |
Low Re SST Transition settings
Eli Shah
Hello Everybody,
I am a beginner in CFD i am trying to simulate the LSB and other coefficients for Low Re 70 000 , using SST transition model , i need help in proper settings , my current settings are : convergence criteria: 1e-4 meshed rotated at -5 for 5 deg AOA Velocity inlet : at X=1.02 , y=0 Intermittency =0 , Turbulence intensity : 0.12 , Turbulence viscosity ratio : 2 pressure outlet: Turbulence intensity : 0.12 , Turbulence viscosity ratio : 2 Intermittency =0 my domain is extended from -15 to 25 times the chord i am using SIMPLE scheme with default settings for relaxation factors 1- how can i capture the LSB ? 2- What do you think about my settings? is it good? 3- what should be the operating conditions at inlet and outlet with rotation of the mesh ? thanks in advance Haseeb |
February 22, 2013, 11:38 |
Eli Shah
Any Help !!
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 19:00 |
SST Model for Low Re ... some minor settings | mrenergy | FLUENT | 7 | January 18, 2013 21:13 |
Very Low Re: SST vs. v2-f? | CAVT | Main CFD Forum | 0 | September 25, 2010 04:34 |
to LANGTRY ROBIN :help, hypersonic transition SST | ben akih | CFX | 0 | September 21, 2006 04:59 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
