March 19, 2013, 15:56 |
writing journal
Umut Can
Hello guys,
I need to output average output values on the surface named "pal". After that i need to save them in a file. I know for the average values i am going to use surface integral section in the report value. But how can i write those values into file by automatically(i.e. by inserting some sentences to the journal file)? |
March 19, 2013, 16:56 |
Stuart Buckingham
Rep Power: 25 |
/solve/monitors/surface/set-monitor surf-mon-1 Integral pressure monitor-surface () no no yes output-file.txt 1 yes time-step
The above will output the integral of pressure at every timestep. |
March 20, 2013, 15:21 |
Umut Can
thank you very much for your answer.
Could i save the picture of the specified surface? |
March 20, 2013, 15:51 |
Ghazlani M. Ali
Rep Power: 28 |
set the driver you want /display/set/drivers jpeg
scale the view /display/views> auto-scale set the number of contour you want /display/set/contours> n-contour select what contour you want to draw /display> contour save the picture file /display/save-picture blabla.jpeg i may have forgot a step, just play around the display sub-menu in the console... |
How to Mix AIR and WATER | Elvis1991 | FLUENT | 12 | December 1, 2016 12:28 |
journal file command for writing mass flow rate | James | FLUENT | 0 | July 26, 2006 10:51 |
Gambit journal writing?? | Dustin | FLUENT | 0 | April 7, 2006 08:39 |
Problems With Journal When Writing Forces To File | Andrew | FLUENT | 2 | September 23, 2005 02:12 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
