convergence problem in 2D steady supersonic flow |
November 4, 2014, 07:10 |
mohamed mohsen
Rep Power: 13 |
Hello Guys ..
I'm simulating a flow over a 2D supersonic airfoil with fluent, steady state, density based solver, structured quad cells with yplus around 2 and SA turbulence model, boundaries are velocity inlet and pressure outlet the problem is the solution doesn't converge such that the residuals are fixed at certain values and the mass flow rate and pressures at certain locations keep oscillating periodically with large amplitude. i tried to reduce the CFL up to 0.01! oscillations exist with less amplitude. Can anybody help with this problem im stuck! |
November 5, 2014, 06:47 |
AAA
Rep Power: 11 |
Hello
As you know, there are various reasons why the solution doesn't converge. I guess the domain of your solution is too small. How big is the size of domain? At least the domain behind airfoil must be approximately 10~15 times the chord length. |
November 5, 2014, 07:47 |
mohamed mohsen
Rep Power: 13 |
yeah the domain behind the airfoil is about 10 times the chord .. i tried pressure inlet boundary and its much much more better than velocity inlet with little oscillations ,, i will try to reduce the CFL with the pressure boundary
November 5, 2014, 18:58 |
#4 | |
AAA
Rep Power: 11 |
I found same problem with your problem.
Please look at this thread. http://www.cfd-online.com/Forums/fluent/112445-pressure-far-field-vs-velocity-inlet-pressure-outlet.html Quote:
November 6, 2014, 07:06 |
mohamed mohsen
Rep Power: 13 |
thank you bro ,, but it seems like pressure boundaries also have fluctuations , i will try to extend the domain much more ans see
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Modeling unsteady multiphase flow in porous media - convergence problem | Vaibhav Kumar | Main CFD Forum | 1 | July 22, 2012 04:32 |
Convergence Problem with body force driven flow | Jinfeng | FLUENT | 1 | December 9, 2009 03:54 |
CFD-ACE compressible flow convergence problem | DelphineL | Main CFD Forum | 1 | October 21, 2009 05:50 |
initialization of flow field to enhance convergence rate to steady state | vfico | Main CFD Forum | 0 | September 9, 2009 11:23 |
