August 5, 2013, 15:39 |
Pressure Oscilations NACA 0012 Transonic
Good Afternoon
I'm simulating some NACA at transonic speeds and when I extract the pressure and pressure coefficients from the wall it's possible to visualize some fluctuations on the pressure plots. I tried to use first and second order squemes, with different courant numbers but the problem still there. In some subsonic simulations I can see this fluctuations too. Is there anyone who knows how to correct this fluctuations ? Some data of my simulation (transonic one) are: SST K-w Mach 0,8 Second order and first order upwind (tried them both) thanks. |
August 6, 2013, 02:18 |
I have had the same problem, I could only diminish the magnitude of the oscillations, but could never get rid of it, by preparing a fine boundary layer grid. Did you also use Icem CFD and construct a block-structured mesh? |
August 7, 2013, 08:23 |
Yes I'm using ICEM CFD. And my mesh is structured.
The first cell is 0.0001 m from the airfoil wall. I checked the y+ and it is around 3 for the airfoil. What's your y+ ? |
August 10, 2013, 19:00 |
I solved my problem by setting the tri tolerance to 10E-7 from 10E-3 (Settings->Model->triangulation) My y+ value is around 1 because I am using enhanced wall treatment. It depends on the wall function.
March 20, 2017, 23:59 |
shuaiG
so it is the mesh that matters at last? i mean the oscillation of pressure coefficient
NACA 0012 Experimental Data | prasad84 | Main CFD Forum | 19 | February 22, 2023 09:03 |
Wrong operator in transonic pressure equation? | dohnie | OpenFOAM Programming & Development | 2 | July 11, 2015 22:16 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
NACA 0012 simulation results | Luis | FLUENT | 3 | February 15, 2006 11:42 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
