Fluent - OpenGL driver
Old   June 23, 2007, 08:29
Default Fluent - OpenGL driver
vof_grid
When I use fluent I get the following:
OpenGL driver was requested but is not available in this Hoops.
Kindly advice to circumvent this issue.
Thanks in advance.
vof_grid.
Old   June 23, 2007, 18:07
Default Re: Fluent - OpenGL driver
CfdNewbie
If you are on a Linux machine as i suspect, you could use in a Terminal something like:
fluent 2ddp -driver x11
or
fluent 3ddp -driver x11
I hope this could help you.
Old   June 24, 2007, 13:25
vof_grid
Hello CfdNewbie,
Your advise has worked like charm. I had problems only with few linux distros like fc6 and f7 and never with fc5. So I was stuck. Thanks for your help.
vof_grid.
Old   July 4, 2007, 05:23
Chirag Jayswal
Thanks CfdNewbie.
Your reply helped me too. I was searching for the same thing.
Old   November 18, 2009, 14:22
Thumbs up You da man
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Thanks CfdNewbie
pranab_jha is offline   Reply With Quote
Old   November 19, 2009, 05:57
Zlatko's Avatar
Zlatko is on a distinguished road
To use opengl driver in fluent on Fedora/Debian/RH linux create file /etc/issue.suse with line:
SuSE Linux 9
Zlatko is offline   Reply With Quote
Old   April 9, 2010, 06:14
Thanasis
thanz is on a distinguished road
Originally Posted by CfdNewbie
;142816
or
thanks, it is also worked for me
thanz is offline   Reply With Quote
Old   December 5, 2012, 01:36
g
emmy is on a distinguished road
i encountered same problem but i'm running it on a windows pc!
any solution? thx alot!
;142816
or
emmy is offline   Reply With Quote
Old   December 8, 2013, 03:41
zongzi is on a distinguished road
Thanks CfdNewbie!
zongzi is offline   Reply With Quote
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
OpenGL problem in Fluent for Linux Jack FLUENT 4 January 23, 2007 06:32
