Superficial Velocity Porous Formulation
Old   December 12, 2013, 12:58
Default Superficial Velocity Porous Formulation
Persil is on a distinguished road
I simulate the flow around a vane with pressure based solver, k-e-model, energy on and pressure in/outlet bcs
The picture shows the distribution of the total temperature but the red spot is definetely wrong. Instead you should be able to see the trail of the trailing edge. This red temperature is even higher than my defined backflow temperature. there was some reversed flow in the beginning of the simulation but that went away. I checked bcs, adjusted under-relaxiation factors and continued simulating until next convergence but the temperature did not behave as wished...
then I stumbled over the superficial velocity porous formulation and I cannot judge if this default setting might cause this temperature anomaly... can anyone explain, if this formulation could influence the temperature distribution? I read the user guide concerning the SVPF but that did not help much
also, I am thankful for any other suggestions that might help fixing this
Persil is offline   Reply With Quote
Old   December 12, 2013, 13:06
Zaktatir is on a distinguished road
This is only used for porous zones. Do you porous zone?
List you numerical and BC details Please
Check the convergence or post the residual plot and flow imbalance report
Zaktatir is offline   Reply With Quote
Old   December 16, 2013, 06:22
no I don't use porous zone. But even without using it, a superficial velocity is applied by default by fluent. The influence of this setting is unknown to me...
bcs: periodic (top/bottom), pressure in-and outlet, stationary wall
no rotating system, 1 cell zone,
using pressure-based solver
methods: green-gauss-cell-based, standard pressure, rest first order then changing to second order (see the spike in the residuals)
Old   December 16, 2013, 12:32
carry on calculating and use local scaling for monitoring the residuals. Watch the imbalances and use PRESTO! for the pressure interpolation and the coupled solver in second stage
Old   December 19, 2013, 07:55
I disabled the absolute convergence criteria in the residuals settings window and carried on iterating which made the irregularities go away
porous media formulation teejey FLUENT 1 April 8, 2020 04:56
Relative Velocity Formulation and Coupled Solutions Jean C FLUENT 0 April 23, 2013 11:50
Porous Formulation hbf FLUENT 1 July 1, 2009 07:20
superficial velocity discovolante Main CFD Forum 0 April 28, 2009 06:52
physical velocity formulation and porous media KLG FLUENT 2 June 10, 2003 10:14
