December 25, 2013, 07:43 |
Iso-surface plot
le hoang anh
Dear Fluent User,
I am modeling cavitation in 3-D Nozzle. I try to plot cavity as in the picture below ( the cavity appare in the Nozzle hole). I tried to use Iso-surface but it not work as I expect. Could some one help me how to do that? Thank you very much! (Sorry I dont know hoe to add image in the forum) This is the image of my model http://img577.imageshack.us/img577/2517/3p2f.jpg And this is the example cavity plot which I want to do http://img29.imageshack.us/img29/1276/xmi6.jpg |
December 25, 2013, 11:33 |
I don't understand: are you asking by which variable you want to the create the iso-plot?
You may create the isoplot by means of the void fraction and then using another variable for post-processing on the created surface |
December 25, 2013, 20:16 |
#3 | |
le hoang anh
I mean do you know how to use Iso-surface or onothe option in Fluent to plot the cavity structure as in picture I posted above? I used contour plot but it just show the position of cavity and we could not see the cavity struture(3D), also I tried to use Iso-surface as advice from anothe topic in Forum or in Fluent guid, but it still not work |
December 26, 2013, 05:15 |
by which variable is the cavity specified? VOF or anything else?
December 26, 2013, 09:12 |
le hoang anh
December 27, 2013, 07:58 |
then follow my first reply and then we will see
December 27, 2013, 08:20 |
le hoang anh
Thank Zaktatir,
But could you tell me detail how to do that? I dont clearly understand you reply |
December 27, 2013, 10:34 |
-1/Create a Surface by Iso-Value (Iso-Surface)
2/ Choose VOF as the variable of interest and give a reference Value 3/Then you have now a new surface which may be used for further post-processing By the why how high is the void fraction for your cavity (0,5?)? |
December 27, 2013, 22:12 |
le hoang anh
I dont kown what value should use, because the VOF value from 0.1 to 0.9
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] Snap Precision to a STL Surface | malaboss | OpenFOAM Meshing & Mesh Conversion | 16 | July 26, 2013 01:44 |
STL units and Surface elevation plot | MAB | FLOW-3D | 11 | May 9, 2010 15:55 |
Is it possible to plot streamline on a user surface | fkzstar | CFX | 2 | April 8, 2009 05:30 |
Can I plot a surface integral as function of time? | Cagdas | FLUENT | 0 | October 24, 2007 17:04 |
