Heating of fluid, cooling of solid
Old   November 23, 2015, 09:50
Question Heating of fluid, cooling of solid
Volkan Gülyüz
vgulyuz is on a distinguished road
Nowadays i'm working on a project which works like a heat exchanger. Consider a heated brick let say has a temperature of 400K and fluid that flows inside of brick has a temp of 300K. In this transient problem, fluid will be hotter and brick gets cooler during flow.
On the other hand, in solution i cant see the cooling of brick because of the constant wall temp bc. How can i solve this situation ? What kind of bc should i use?
Looking forward for your reply,
best regards
Gulyuz
vgulyuz is offline   Reply With Quote
Old   November 23, 2015, 15:54
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Maybe what you have to do is select convection under wall thermal conditions, specify free stream temperature (ambient temperature) and most importantly the heat transfer coefficient. This should work out fine.
-BB
bhargavbharathan is offline   Reply With Quote
cooling of solid, heating of fluid
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
