November 23, 2015, 09:50 |
Heating of fluid, cooling of solid
Volkan Gülyüz
Rep Power: 11 |
Nowadays i'm working on a project which works like a heat exchanger. Consider a heated brick let say has a temperature of 400K and fluid that flows inside of brick has a temp of 300K. In this transient problem, fluid will be hotter and brick gets cooler during flow. On the other hand, in solution i cant see the cooling of brick because of the constant wall temp bc. How can i solve this situation ? What kind of bc should i use? Looking forward for your reply, best regards Gulyuz |
November 23, 2015, 15:54 |
Bhargav Bharathan
Rep Power: 10 |
Maybe what you have to do is select convection under wall thermal conditions, specify free stream temperature (ambient temperature) and most importantly the heat transfer coefficient. This should work out fine. -BB |
cooling of solid, heating of fluid |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Re-meshing a deformable solid body in a fluid | brashear | CFX | 6 | December 12, 2011 11:13 |
