Temperature Miscount
Old   February 21, 2014, 07:20
Default Temperature Miscount
Mullop is on a distinguished road
hello!!
i am working a simulation on radial gas turbine. i am using energy and k-epsilon model. setting boundary on inlet as mass-inlet and outlet as press-outlet.
after running the simulation, i find that the temperature outlet is just the same with inlet.
is there any suggestion?
Mullop is offline   Reply With Quote
Old   February 21, 2014, 08:45
pakk will become famous soon enough
Suggestion 1: your simulation correctly described what is happening, and the temperature at the outlet really is the same as in the inlet.
Suggestion 2: you did not calculate the energy equation. Check at 'Models' if the energy equation is really on, and check at 'Solution controls'->'equations' if it is also calculated.
Is the temperature everywhere in the domain the same, or only at inlet and outlet?
pakk is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 04:03
