Dynamic cylinder mesh
Old   March 4, 2014, 09:46
Unhappy Dynamic cylinder mesh
Jack Holmes
jackholmes is on a distinguished road
Hi I want to create a very simple Cylinder radius 38.1mm and length 111.1 mm that compresses then expands to its original size.
I am stuggling on how to even start.
Any help would be great
Thanks
Jack
jackholmes is offline   Reply With Quote
Old   March 4, 2014, 13:14
Mack
Mack is on a distinguished road
Hi Jack,
As your geometry is quite simple, you can create it directly on your meshing program (ICEM, gambit..), instead of generating it on a CAD software. There is no problem that you do not have inlets or outlets, just define the walls.
After uploading the mesh on fluent you can use the in-cylinder option, defining the stroke (through the crank radius) and the speed of the movement (through the crank shaft speed). Remember to take care about the clearance at the smallest volume position, otherwise you will have negative volumes during the mesh movement. There is a 2-D in-cylinder tutorial for fluent (internal combustion engine), which I recommend you take a look.
Hope it helps,
Mack
Mack is offline   Reply With Quote
cylinder, dynamic mesh, fluent, piston
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 08:59
[GAMBIT] How to mesh a cylinder with fine to coarse cells Bharatt ANSYS Meshing & Geometry 3 August 12, 2013 00:45
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
