DO radiation through consecutive glass panels
Old   June 8, 2022, 16:24
Default DO radiation through consecutive glass panels
helena_30 is on a distinguished road
Hi to all,
I am trying to simulate a 2d radiation problem using the DO radiation model of fluent.
The setup consists of a double glass window (each with a width of 2cm) with an air cavity in the middle as shown in the attached figure. Incoming radiation comes from the external environment. For the glass windows I have the absorptivity (e.g. 0.2), reflectivity (e.g. 0.3) and transmissivity (e.g. 0.5) coefficients.
The DO radiation model requires as input the following parameters:
Absorption coefficient (1/m)
Scattering coefficient (1/m)
Refractive index
Internal emissivity
Diffuse fraction
Can anyone explain in a simple way how do I treat the above parameters based on the three coefficients that I have?
Thanks in advance for the advise
helena_30 is offline   Reply With Quote
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 10:29
Radiation Heat transfer through glass to the water parmeshwar FLUENT 2 April 20, 2016 16:55
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Radiation through: glass – air cavity – glass Yingchun CFX 7 February 27, 2012 16:46
