DO radiation through consecutive glass panels |
June 8, 2022, 16:24 |
Hi to all,
I am trying to simulate a 2d radiation problem using the DO radiation model of fluent. The setup consists of a double glass window (each with a width of 2cm) with an air cavity in the middle as shown in the attached figure. Incoming radiation comes from the external environment. For the glass windows I have the absorptivity (e.g. 0.2), reflectivity (e.g. 0.3) and transmissivity (e.g. 0.5) coefficients. The DO radiation model requires as input the following parameters: Absorption coefficient (1/m) Scattering coefficient (1/m) Refractive index Internal emissivity Diffuse fraction Can anyone explain in a simple way how do I treat the above parameters based on the three coefficients that I have? Thanks in advance for the advise |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 10:29 |
Radiation Heat transfer through glass to the water | parmeshwar | FLUENT | 2 | April 20, 2016 16:55 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Radiation through: glass – air cavity – glass | Yingchun | CFX | 7 | February 27, 2012 16:46 |
