February 25, 2016, 08:27 |
UDF for temperature initialization in FLUENT
ami
Rep Power: 10 |
I am modeling thermal stratification in a tank full of water. Usually, the initial temperature which I use is uniform and equal to 25°C. Now, I want to model a special initial state. The temperature of the upper part of the tank is 62°C and the temperature of the lower part of the tank is 25°C. It is the same fluid in the tank (the fluid is water). There is no wall between the upper and the lower parts. Can you help me please for modeling this case? I have attached a picture for the initial state which I want to model in FLUENT. thank you in advance for your help |
Wind turbine rotation through UDF in FLUENT | Shamoon Jamshed | Fluent UDF and Scheme Programming | 10 | June 25, 2018 12:58 |
fluent udf, saving data in udf | mohsen zendehbad | Fluent UDF and Scheme Programming | 15 | June 13, 2017 23:23 |
Problem running fluent with udf on batch | tobi b. | Fluent UDF and Scheme Programming | 3 | April 14, 2016 13:54 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 10:57 |
