UDF for temperature initialization in FLUENT
Old   February 25, 2016, 08:27
Default UDF for temperature initialization in FLUENT
ami
Ami24 is on a distinguished road
I am modeling thermal stratification in a tank full of water. Usually, the initial temperature which I use is uniform and equal to 25°C. Now, I want to model a special initial state. The temperature of the upper part of the tank is 62°C and the temperature of the lower part of the tank is 25°C.
It is the same fluid in the tank (the fluid is water). There is no wall between the upper and the lower parts.
Can you help me please for modeling this case?
I have attached a picture for the initial state which I want to model in FLUENT.
thank you in advance for your help
Ami24 is offline   Reply With Quote
Wind turbine rotation through UDF in FLUENT Shamoon Jamshed Fluent UDF and Scheme Programming 10 June 25, 2018 12:58
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 13:54
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
