[Sponsors] | |||||
Abdalla
Rep Power: 14 ![]() |
Hi guys,
i have to simulate the water flow through an open bowl, were carbon fiber is beeing washed. Anyway, I successfully set a fluid domain and let the water flow with different temperatures and velocities. It looks like this: (Symmetry view) Fluiddomain: 3_Solid_Water_End.jpg Temp: temp.jpg An interaction with the atmosphere is not given. Fluent declaired the top surface of the fluiddomain as a wall. How do I fix this, so the water hight is not blocked by the "wall"? should I for example put a second fluid domain for air and handle the problem as multiphase? thank you
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
| Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 17:28 |
| OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 12:03 |
| Problems with BCs in muliphase flow with water falling from a reservoir | Paul_l | FLUENT | 2 | March 11, 2011 05:59 |
| uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
