pressure drop calculation
Like Tree2Likes
  • 1 Post By swiftaircraft
Old   October 15, 2014, 13:56
Default pressure drop calculation
ayad's Avatar
ayad
ayad is on a distinguished road
I was simulating finned tube heat exchanger shown in figure, how can i calculate pressure drop(pressure losses by H.E)? Does it calculated by drawing a line or vertex before and after the pipes? Where is the best position to draw the line or vertex?
ayad is offline   Reply With Quote
Old   October 20, 2014, 07:39
ayad's Avatar
ayad
Any way please?
Old   October 20, 2014, 15:08
David Stanbridge
swiftaircraft is on a distinguished road
If the left side is the inlet and the right side the outlet you can simply take the mass weighted pressure averages over both and then take one from the other. Or are your inlets and outlets not in these places?
Maddin likes this.
David Stanbridge
Swift TG Solutions Limited
www.swifttgsolutions.com
swiftaircraft is offline   Reply With Quote
Old   October 20, 2014, 15:27
ayad's Avatar
ayad
thank u for your reply
As u say, the left side is inlet and the right side is outlet.
this duct is one part,did the result will be average of all duct if i do that ?
i thought that the pressure drop can be calculated by drawing a plain after and before the pipe and take the first from the other, is this way right?
Old   October 21, 2014, 02:22
David Stanbridge
Assuming that you have applied translational periodics then taking the mass weighted average pressure on the inlet and the outlet will be the average of the complete duct. If you need to define the pressure loss at different locations to where you have the inlet and the outlet then you will need to set up different surfaces. However to do this precisely these lines should have been set up before the model was meshed. By the looks of the model you have used periodics with a symmetry plane. Is that correct?
David Stanbridge
Old   October 21, 2014, 05:27
ayad's Avatar
ayad
Thank you for your interesting
I've got a result by drawing two plane(surface) after and before the tubes, and take one from the other after computing the face average pressure for each plane.
is this the first way you told me about?
Old   October 21, 2014, 07:34
David Stanbridge
That is a valid way to do it.
ayad likes this.
David Stanbridge
Old   October 21, 2014, 08:32
ayad's Avatar
ayad
Thank you so much
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
Mass flow rate prediction of Purge control valve using set pressure drop enr_venkat CFX 11 February 27, 2014 11:30
Pressure drop calculation and comparison to analytic solutions n0name STAR-CCM+ 2 August 16, 2012 03:36
pressure drop calculation multi-inlet-outlet syst. timmyy FLUENT 1 April 24, 2007 06:03
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
