November 19, 2014, 20:47 |
Force air-cooled oil tank
Paul Aguirre
Rep Power: 11 |
I'm currently working on a project in ANSYS fluent designing a force air-cooled oil tank by cooling tubes. I'm also very new at dealing with fluent so I don't know much on how to set up the solution.
The tank must be full before it starts draining. Here are some specs that I'm not sure how to set up Oil Inlet temperature = 225˚F Oil Inlet Pressure = 60psi Air pressure = .008373 psi Air temperature = 95˚F Air density = .0614 lbm/ft3 |
November 20, 2014, 10:08 |
It is not clear which is your problem. If you have the boundary conditions, you just have to properly set them.
If the air speed is low, you can simulate both air and oil as incompressible fluids. In addition to the BC you mentioned, you have to set the mass flow or the outlet static pressure. Hope this helps. |
November 20, 2014, 11:07 |
Paul Aguirre
Rep Power: 11 |
I think the BC's and Cell Zone condition might be my problem then. I'm not sure in setting them up.
I have figured out the inlet BC as a pressure inlet at 60 psi and I know the outlet is supposed to be set as a pressure outlet, but I'm not sure what the psi is supposed to be for the outlet? Nor do I know what type of inlet my air-flow is supposed to be. Lastly, how do I have the tank fill up before it starts flowing through the outlet? |
November 20, 2014, 11:14 |
Rick
Rep Power: 26 |
Hi Paul,
I suggest to look at tutorials before starting your case. Boundary conditions are inputs, if you don't know your inputs you cannot calculate anything and you can't ask here what are your boundary conditions, simply because we don't know . If you want to set a pressure outlet bc you must know what is the pressure outlet, and what are the flow conditions at the outlet. Air inlet bc depends on your case: for example if air enters at 60 psi and the outlet is at atmospheric pressure you have to treat air as compressible, so you can set a mass flow inlet bc. If air flow is incompressible (i.e. density does not change too much in your domain) you can set a pressure inlet or velocity inlet bc. It seems you need to set up a transient vof simulation, so you can initialize your domain filled with primary phase and then patch the zone you want with the secondary phase.
Google is your friend and the same for the search button! |
November 20, 2014, 11:28 |
Well, let me summarize your problem for what I have understood: you have a tank full of hot oil. There are also some pipes full of cold air submerged in the oil. The two fluids are always separated. The pipes walls are "coupled" in order to allow heat transfer.
You have the following BC: air inlet, air outlet, oil inlet, oil outlet. You have to enable energy equation in order to simulate heat transfer, and also to properly set turbulence model (check Re number if it is necessary). If the fluids are incompressible (low speed for air) you can set outflow BC (but you need to set also the mass flow at inlet or velocity). Otherwise, set the pressure Drop and check for the results. |
November 20, 2014, 12:13 |
Paul Aguirre
Rep Power: 11 |
Yes Lucar, that is exactly the problem. I'll see if this works.
November 20, 2014, 12:39 |
Paul Aguirre
Rep Power: 11 |
I have the tube walls coupled, but I'm getting an error in my solution.
Error: Divergence detected in AMG solver: pressure correction Error Object: #f |
November 20, 2014, 16:41 |
You have to change the initialization: avoid strong gradients. Try also to reduce Under Relaxation Factors.
Check this post: http://www.cfd-online.com/Forums/flu...omentum-2.html |
November 20, 2014, 17:47 |
Paul Aguirre
Rep Power: 11 |
Okay that problem is fixed. Only thing is to specify which liquid/gas goes in which opening. I've tried to use Mixture and Volume of liquid, but that didn't help with 2 phases and I'm just not getting the right result for flow.
November 21, 2014, 07:25 |
You have to enable "models->species->species transport".
The you have to set your mixture (Air + Oil) in the material menu. In this way, you will be able to set a "concentration" for each BC. For Air you will set 100% air, 0% oil. For oil 100%oil 0%air. Consider that the last specie you set in the mixture is used as "complement to 1", so it is automatically set at the BC simply as "1 - other species". This is the reason why you will be able to set just one single number at each BC. Hope this helps. |
November 21, 2014, 13:16 |
#11 |
Paul Aguirre
Rep Power: 11 |
Does the model "multiphase" need to be on?
November 21, 2014, 16:48 |
#12 |
No, I don't think you need multiphase flow.
November 21, 2014, 17:27 |
#13 |
Paul Aguirre
Rep Power: 11 |
In the materials section do I need to specify it as a mixture?
November 21, 2014, 18:06 |
#14 |
Yes, you have to set it as a mixture even though you will utilize both fluids as pure species. I don't think there exist other options...it should work.
November 21, 2014, 18:17 |
#15 |
Paul Aguirre
Rep Power: 11 |
Everything seems right, but I'm getting an error.
"Error: Divergence detected in AMG solver: pressure correction. |
November 21, 2014, 18:49 |
#16 | |
Filling Tank with Water | leff | CFX | 7 | August 21, 2017 07:47 |
Velocity profiles of air with different tank pressures | Dknot | Main CFD Forum | 0 | November 9, 2014 12:14 |
Simple Water Tank Transient | 88phil88 | CFX | 5 | March 17, 2014 03:48 |
Mass conservation problem in mixing tank multiphase simulation | rockewan | FLUENT | 0 | April 6, 2010 12:34 |
boundary condition for a gassed agitated tank | fiona | Main CFD Forum | 4 | March 23, 2010 10:27 |
