Suction on airfoil boundary!!
Old   December 1, 2014, 16:43
Question Suction on airfoil boundary!!
Helena
ABC1234 is on a distinguished road
I'm trying to model a perpendicular suction outlet at 10% chord on a NACA 0012 airfoil.
I have created the mesh in ICEM and imported into fluent. It is an incompressible flow situation with a mach number of 0.3. I am using SST and using a boundary condition of velocity inlet, normal to boundary with a negative velocity of half free stream velocity (around -22.5m/s)
The results for this mesh with no suction inlet are pretty good at low angles of attack in terms of cl and cd close to experimental data but with this suction applied they just go totally astray. I've tried a number of times and mainly they both go negative or ridcliously huge values.
This is for a university final year project so if anyone could help me with what I could be doing wrong I would really appreciate it, I also want to demonstrate blowing in the same slot so if you could tell me what is the best boundary condition for that too it would really help.
Thanks
ABC1234 is offline   Reply With Quote
Old   April 22, 2020, 04:32
Dronzer's Avatar
Dronzer is on a distinguished road
Hi Helena,
Can you explain a bit more about how to model the boundary layer suction problem? I am currently trying to simulate it.
Your suggestion will be valuable.
Please spend some time to share your experience.
Thanks in advance.
Dronzer is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 4 March 17, 2011 06:49
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 0 March 4, 2011 07:48
suction boundary conditions morteza08 Main CFD Forum 0 August 18, 2010 07:47
